Moving portal.php from /forum to root
Brogan
Post by Brogan »
Installed the portal.
Nothing yet.
I have just installed the Board3 portal according to the instruction.
The phpBB forum is installed at e.g. www.mysite.com/forum/index.php
The portal is currently installed at e.g. www.mysite.com/forum/portal.php
How easy is it to move the portal.php page up 1 level to the domain root so it is e.g. www.mysite.com/portal.php ?
Thanks in advance.
Brogan
Re: Moving portal.php from /forum to root
Post by Brogan »
It's OK, I've sorted it with a simple edit of portal.php and the overall_header & footer.
Brogan
Post by Brogan »
Thanks.
I did a search but it didn't find that thread.
Brogan
Post by Brogan »
Well I've tried the steps in that thread but it didn't solve everything.
In the overall_header.html file, {U_PORTAL} is referenced and it still points to /forum/portal.php
Where is U_PORTAL defined?
Thanks.
Brogan
Post by Brogan »
Anyone?
I don't really want to have to edit overall_header with the actual path to the portal.php file in the domain root.
I would much rather edit the U_PORTAL variable and do it properly.
Ice
Post by Ice »
It's one of the edits you do to functions.php I believe.
Brogan
Post by Brogan »
Well as this is an important issue, are any of the designers available to comment?
I need to ensure I capture all of the required edits.
Ice gave already the answer.
In functions.php:
        'U_PORTAL'                => append_sid("{$phpbb_root_path}portal.$phpEx"),
Brogan
Post by Brogan »
Thanks for the confirmation.
So in summary then, I need to do the following:
Move portal.php to root
Rename it to home.php (this is what I plan to do)
Edit home.php
From: $phpbb_root_path = (defined('PHPBB_ROOT_PATH')) ? PHPBB_ROOT_PATH : './';
To: $phpbb_root_path = (defined('PHPBB_ROOT_PATH')) ? PHPBB_ROOT_PATH : './forum/';
Edit functions.php
From: 'U_PORTAL' => append_sid("{$phpbb_root_path}portal.$phpEx"),
To: 'U_PORTAL' => append_sid("home.$phpEx"),
Edit portal/block/login_box.php
Update index.html file to point to new path
From: <meta http-equiv="refresh" content="0;url=forum/portal.php">
To: <meta http-equiv="refresh" content="0;url=home.php">
Is that it?
Do I need to make any other edits?
Thanks in advance.
Brogan
Post by Brogan »
Well those edits above aren't enough.
The portal path in overall header is still pointing to /forum/home.php
In addition, after logging in the page is redirected to /forum/home.php
So it would seem there is still a definition for {U_PORTAL} somewhere that needs to be changed.
Can any of the designers confirm where this is?
Brogan
Post by Brogan »
This has now been solved.
The U_PORTAL definition in functions include needs to be: 'U_PORTAL' => append_sid("../home.$phpEx"),
