Your Portal Version: 1.0.2
Boardlink: http://www.originalsbyoliveira.com/test
I followed the install directions for the MOD, uploaded all the changed files and directed my browers to the install folder.
I opened the functions.php file made sure I did the correct changes but it still doesn't work.
After I directed my brower to load the install php file I got the following error:
Parse error: syntax error, unexpected T_VARIABLE in /includes/functions.php on line 2989
Not sure what the error is with line 2989. It reads:
$l_return_index = sprintf($user->lang['RETURN_INDEX'], '<a href="board3portal_1_0_2/'%20.%20$phpbb_root_path%20.%20'">', '</a>');
Can someone help? I am very new to this and don't understand code that well.
Install Portal php Error
Re: Install Portal php Error
Anyone who can help...I'd appreciate it.
Check your edits to the includes/functions.php (of the phpBB3 core system) - there seems to be something screwed up.
If you don't get along with it, please link to a *.txt file, containing the content of your functions.php.
I checked my edits and did a new upload and tried to install with another error. It's now on line 3000. It reads:
$l_return_index = '<a href="../Documents/Downloads/Board3Portalv1.0.2/board3portal_1_0_2/'%20.%20$phpbb_root_path%20.%20'">Return to index page</a>';
Here's a link to my function file.
http://us.f13.yahoofs.com/bc/45da7baf_c ... IB0NMSGmde
I have no idea what instructions you followed but there is no instruction to change either of those lines.
Line 3000 should read:
$l_return_index = '<a href="' . $phpbb_root_path . '">Return to index page</a>';
I didn't change the lines. After I uploaded the file and tried running the install, I then downloaded the file to look at the error and it was changed. I am not sure why it happened or if it's possible but I looked at my original file I uploaded and it didn't have that text in it.
