Custom Left side menu.
OpTaylor
Post by OpTaylor »
Boardlink: http://www.clanhook.com/phpBB3/portal.php
No problem just a question.
is it possible to make the left side menu look somthing like?
Link to image http://www.clanhook.com/Capture.JPG
1234homie
Re: Custom Left side menu.
Post by 1234homie »
its possible... changing template (menu_block)... xP paste codes to images and in image html tags paste links... its easy to work :D
OpTaylor
Post by OpTaylor »
What does the L and M mean in {L_M_MENU}? Is that a permissions thing? so how would i go about linking to the pages i want in forum using those same permisions???
And is this the only file i will have to modify? I think that doin something like this would be cool through out my entire forum. Looking on how to add menu to black_pearl style now...
<!--version $Id: main_menu.html 344 2008-08-24 20:50:39Z kevin74 $ //-->
<table class="tablebg" cellspacing="1" width="100%" id="navigation">
		<th><span style="float: left"><img src="{T_THEME_PATH}/images/portal/portal_menu.png" width="16px" height="16px" alt="" />&nbsp;{L_M_MENU}</span></th>
	<tr class="row3">
		<td>
			<strong>{L_M_CONTENT}</strong>
	<tr class="row1">
		<td>
	<!-- IF S_DISPLAY_SEARCH -->
	<tr class="row1">
		<td>
			<a href="{U_SEARCH}">{L_SEARCH}</a>
	<!-- IF not S_USER_LOGGED_IN and S_REGISTER_ENABLED -->
	<tr class="row1">
		<td>
			<a href="{U_REGISTER}">{L_REGISTER}</a>
	<tr class="row1">
		<td>
			<a href="{U_MEMBERLIST}">{L_MEMBERLIST}</a>
	<tr class="row1">
		<td>
			<a href="{U_TEAM}">{L_THE_TEAM}</a>
	<!-- IF U_MCP -->
	<tr class="row1">
		<td>
			<a href="{U_MCP}">{L_MCP}</a>
	<!-- IF U_ACP -->
	<tr class="row1">
		<td>
			<a href="{U_ACP}">{L_M_ACP}</a>
	<tr class="row3">
		<td>
			<strong>{L_M_HELP}</strong>
	<tr class="row1">
		<td>
			<a href="{U_FAQ}">{L_FAQ}</a>
	 <tr class="row1">
		<td>
			<a href="{U_M_BBCODE}">{L_M_BBCODE}</a>
	<tr class="row1">
		<td>
			<a href="{U_M_TERMS}">{L_M_TERMS}</a>
	<tr class="row1">
		<td>
			<a href="{U_M_PRV}">{L_M_PRV}</a>
OpTaylor
Post by OpTaylor »
maybe no one's tried this before.... i've tried lookin on the PHPBB forums and they have nothing either.... grrr... maybe i put this in impossible bin... :(
