Deleteing install_portal/install.php causes sql eror
ssei95
Post by ssei95 »
New install of the portal.
Tried running the installer again.
I was able to install the portal and all seems fine. I can navigate to and from the portal and it integrated great with the board. When I go to remove the file .../install_portal/install.php the portal then fails and gives me this error:
SQL ERROR [ mysql4 ]
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'AND in_message = 0 ORDER BY filetime DESC' at line 4 [1064]
[/i]
EDIT: After trying various simple things, I found that the file name only is what it is looking for. I placed an empty file called install.php in the location and the portal came back online. Not sure what or where would be referencing that file.
ssei95
Re: Deleteing install_portal/install.php causes sql eror
Post by ssei95 »
WOW... Figured this one out I think... I renamed the directory by adding characters to the end of the "install_portal" folder name. Apparently the portal.php still parsed out the original name form it. Once I added the additional characters to the front of the folder name, SQL error went away and all looks fine now. Porblem was my fault, but it's fixed now. :oops:
That is odd. This code in the portal.php is responsible for this:
if ( is_dir( $phpbb_root_path . 'install_portal/' ) === TRUE )
So if you even name it install_portalxxx it shouldn't blame you anymore.
May i ask which Database and PHP Version do you use?
ssei95
Post by ssei95 »
I'm using phpbb 3.01 and Mysql 5.0.51a-community
I found that code when I was troubleshooting, and tried removing/editing it with no luck (I'm not that good at php yet). That was all I found, which is why I was confused. Either way, the portal is live on my board and people are loving it! One of the best mods I ever added.
