My Portal is Not Valid XHTML 1.0 Strict
Shadowz O Death
Post by Shadowz O Death »
Your Portal Version: 1.0.2
Boardlink: http://www.the7thhour.net/
PHP Version: 5.2.8
MySQL Version: 5.0.67
Hello everyone! I have just installed phpBB 3.0.4 and board3 Portal 1.0.2. For some reason, my portal is not Valid XHTML 1.0 Strict. The results of my W3C validation test are at http://validator.w3.org/check?uri=http% ... or%2F1.606. What files and code do I have to edit in order for my portal to be Valid XHTML 1.0 Strict? Thank you so much! :D
Re: My Portal is Not Valid XHTML 1.0 Strict
Check again the install.xml
It looks like there is something wrong - eg. the left and right columns don't have any space to the left and the right.
Normally it should look like this: portal.php?style=1 - the portal itself shouldn't be wider than the header.
So i guess that somethings gone wrong during the file edits or you've changed something else in the templates.
Also purge your board cache and refresh your templates.
Shadowz O Death
Kevin wrote:Check again the install.xml
You are correct. After looking over the file edits, I added
after
instead of after
What happened was when I was going to search for it, I copied and pasted
into a single-line text box, which caused it to only paste
Thank you for your help!
