Update to 1.0.3 confused on what to install?
FLATTOP
Post by FLATTOP »
Your Portal Version: 1.0.2
Hey, I'm trying to update from 1.0.2 to 1.0.3 and the update instructions say to browse to install/ and run the installer, ok..., which install script should I point to? from the avaiable options in the install folder, I'm "guessing" it should be install_update.php, is that correct?
Also the update instructions do not say to delete the install folder after update/install, so again I'm guessing I should delete the install folder?
Re: Update to 1.0.3 confused on what to install?
FLATTOP wrote:Hey, I'm trying to update from 1.0.2 to 1.0.3 and the update instructions say to browse to install/ and run the installer
Just browse to the www.yourdomain.de/install/ - there is a menu, where you can choose the update.
FLATTOP wrote:Also the update instructions do not say to delete the install folder after update/install, so again I'm guessing I should delete the install folder?
Delete it afterwards. But there is a message to do so, after the installation. ;)
FLATTOP
Post by FLATTOP »
thanks for the help, that's easy enough
Onetimer
Post by Onetimer »
Are there any changes made to styles and/or language files?
Yes... both of them.
Oshadha
Post by Oshadha »
I'm also trying to update from 1.0.2 to 1.0.3 but in the installation there's a missing piece
adm/index.php the replacement code was not there what shall i do.
This might be a bit confusing, although it is correct. This simply means: delete the code you have to search for.
Search --> replace with "nothing". ;)
We have the problem that there is no "delete" tag for the ModX files. This is why we have to do it that way.
Oshadha
Post by Oshadha »
Thanks Kevin, then again another problem. I did all the things that as instructed but when i try to refresh prosilver template via ACP it gives an error
Where can i find this file i checked the root folders cant find
This file must belong to another mod. We don't have a "colour_swatch.html"
Oshadha
Post by Oshadha »
Kevin wrote:This file must belong to another mod. We don't have a "colour_swatch.html"
Thanks i have solved it .... :D
