Get the panels on the Fourm index
Forgoten Dynasty
Post by Forgoten Dynasty »
I want to get the Recent members and top posters on my forum index
so i can kind of get this effect
Bible Poet
Re: Get the panels on the Fourm index
Post by Bible Poet »
Don't know if this will help but if you go to phpBB and post in the request section someone might be able to help.
This site is for Board 3 Portal. Anything for the forum is over at /www.phpbb.com
Forgoten Dynasty
its been suggested multiple times at phpbb no one does it
im posting here because i want to use this portals blocks :roll:
Bible Poet
Well if you want to use this block on the portal then you would have turn it in to a template html file and save it to prosilver/templates/portal/block/ .
then you would have to call it from the Portal.php where you would like it to display. You would not have any control of it in the acp. but you could make changes to the html file that you created.
Hope that this helps.
