[Release] mChat Block for Board3 Portal 1.0.5 & 1.0.6
Addon: mChat Block
Addon Version: 1.0.3
Addon Author: Marc Alexander
Addon Description:
Adds an mChat window to your portal page.
Addon Requirements: Board3 Portal 1.0.5 and newer and mChat 1.3.4 by RMcGirr83
Instructions:
Open portal/block/additional_blocks.php
Find:
Add before:
	// mChat Block for Board3 Portal 1.0.5 and 1.0.6
	if($load_center)
		if(!defined('MCHAT_INCLUDE'))
			define('MCHAT_INCLUDE', true);
		if(!function_exists('mchat_cache') && !empty($config['mchat_enable']) && $auth->acl_get('u_mchat_view'))
			$mchat_include_index = true;
			include($phpbb_root_path . 'mchat.' . $phpEx);
			$template->assign_var('S_MCHAT_PORTAL', true);
	// mChat Block END
Open styles/prosilver/template/portal/portal_center.html
Find:
<!-- INCLUDE portal/block/additional_blocks_center.html -->
Add before:
<!-- IF S_MCHAT_PORTAL --><!-- INCLUDE mchat_body.html --><!-- ENDIF -->
Note: The prosilver and subsilver2 template changes are the same.
Portalview Changes:
Open portal/includes/portalview.php
Find:
// load blocks in the left column
Add before:
$load_center = false; // we don't show the center column
cLinch3r
Re: [Release] mChat Block for Board3 Portal 1.0.5 & 1.0.6
Post by cLinch3r »
Thanks Marc for posting this.
I had recently lost my hosting and all the files for my forum went with it. So I'm starting from scratch and forget some of the edits that made things work the way had it.
This helps alot.
8-)
xnigelx
Post by xnigelx »
how would i apply my portal style to this block, below is the code for a blank center, but i just dont know where to add this in the mchat_body or what to take out.
<!--version $Id: custom_center.html 521 2009-08-26 20:59:19Z christian_n $ //-->
{$C_BLOCK_H_L}<dt>{PORTAL_CUSTOM_CENTER_HEADLINE}</dt>{$C_BLOCK_H_R}
<div class="panel bg1" style="margin-bottom: 0px">
			<div class="content">{PORTAL_CUSTOM_CENTER_CODE}</div>
{$C_BLOCK_F_L}{$C_BLOCK_F_R}
thanks
Updated to version 1.0.1.
MoDuL
phpBB.com User: MoDuL
Post by MoDuL »
What should be done if i don't have this file? portal/includes/portalview.php?
In portal/includes/ i see only 3 files
1. functions.php
2. functions_version_check.php
3. index.html
That's why it says portalview changes. You only have to do this edit if you have Portalview installed. If you don't have that file, you probably don't have Portalview installed.
Sortilege
Post by Sortilege »
Hi all i'm very interesting about that function for mchat.
it is runing on our forum but when i want to edit files for put mchat block i don't find files
I'm using prosilver style
you can looking our portal in http://www.team-jpf.org/portal.php
the chat run on http://www.team-jpf.org
i can't find how to do for put the portal for default page
Thanx a lot about your help
You are still running Board3 Portal 1.0.2. Please update to the newest version.
Sortilege
Post by Sortilege »
Hi and thanx about your speedly answer.
I know i have that version but it's french version, I'm waiting the new translation before update.
I'll wait with mchat on forum only for the moment
Thanx again
There are french translations for Board3 Portal 1.0.6:
viewtopic.php?f=13&t=3962
Sortilege
Post by Sortilege »
Lol i didn't see it.
i've just install english version :)
thanx i'll try to update english to french
Sortilege
Post by Sortilege »
translation updated thanx again.
One more things i don't have portalview.php on portal/includes directory is it normal ?
i create that file and edit with php code.
Marc wrote:That's why it says portalview changes. You only have to do this edit if you have Portalview installed. If you don't have that file, you probably don't have Portalview installed.
Sortilege
Post by Sortilege »
i'll do what it need to install it
Where can i find it please ?
Thanx a lot
If you only have Board3 Portal installed, you do not need to do the changes for Portalview.
