CA Black (Base: prosilver)
Style: CA Black
Style Version: 1.0.3
Style Download: http://www.stsoftware.biz/phpbb30_style.ca_black.html
to: root/styles/ca_black/template/portal/*.*
to: root/styles/ca_black/theme/portal.css
to: root/styles/ca_black/theme/images/portal/*.*
open: root/styles/ca_black/template/overall_footer.html
open: root/styles/ca_black/template/overall_header.html
<div class="topnav">
<div id="page-body">
open: root/styles/ca_black/theme/stylesheet.css
open: root/styles/ca_black/template/portal/_block_config.html
<!-- DEFINE $LR_BLOCK_H_L = '<div class="block-header"><span><span></span></span></div><div class="block-content"><div class="block-inner"><ul class="topiclist"><li class="header"><dl class="icon"><dt style="margin-left: 2px; margin-top: 0px; width: 140px;">' -->
<!-- DEFINE $LR_BLOCK_H_R = '</dt></dl></li></ul><div style="padding:4px;">' -->
<!-- DEFINE $LR_BLOCK_F_L = '</div>' -->
<!-- DEFINE $LR_BLOCK_F_R = '<div class="block-clear"></div></div></div><div class="block-footer"><span><span></span></span></div>' -->
<!-- DEFINE $C_BLOCK_H_L = '<div class="block-header"><span><span></span></span></div><div class="block-content"><div class="block-inner"><ul class="topiclist"><li class="header"><dl class="icon"><dt style="margin-left: 2px; margin-top: 7px;">' -->
<!-- DEFINE $C_BLOCK_H_R = '</dt></dl></li></ul><div style="padding:4px;">' -->
<!-- DEFINE $C_BLOCK_F_L = '</div>' -->
<!-- DEFINE $C_BLOCK_F_R = '<div class="block-clear"></div></div></div><div class="block-footer"><span><span></span></span></div>' -->
<!-- DEFINE $CC_BLOCK_H_L = '<div class="block-header"><span><span></span></span></div><div class="block-content"><div class="block-inner"><ul class="topiclist"><li class="header"><dl class="icon">' -->
<!-- DEFINE $CC_BLOCK_H_R = '</dl></li></ul><div style="padding:0px;">' -->
nach: root/styles/ca_black/template/portal/*.*
nach: root/styles/ca_black/theme/portal.css
nach: root/styles/ca_black/theme/images/portal/*.*
Öffne: root/styles/ca_black/template/overall_footer.html
Öffne: root/styles/ca_black/template/overall_header.html
Öffne: root/styles/ca_black/theme/stylesheet.css
Öffne: root/styles/ca_black/template/portal/_block_config.html
