IS there a Portal Update Available?
Solidjeuh
phpBB.com User: Froddelaar
Re: IS there a Portal Update Available?
Post by Solidjeuh »
Solidjeuh wrote: 1. February 2017 17:36
Lance wrote: 1. February 2017 15:31 Is there an English translation of the instructions for phpBB 3.2?
When I try to translate that page, the best I can figure out is to delete a lot of stuff but not replace it with anything.
Or will there be a new, update Portal for 3.2?
Thanks!
Use my files, they work on 3.2
You just need to empty your browser history and forum cache.
https://www.supportforum.be/private/scripts/board3.zip
Updated the files with the permission fix.
Register a free account & Play!!
~~~ https://www.solidjeuh.be ~~~
Have a secret? --> https://www.tellyoursecrets.eu
JohnnyBigspuds
phpBB.com User: JohnnyBigSpuds
Post by JohnnyBigspuds »
https://www.froddelpower.be/scripts/board3.zip
The link no longer works, do you still have this available please?
Solidjeuh
Post by Solidjeuh »
JohnnyBigspuds wrote: 12. December 2017 23:17
Sorry, my other website is offline.
Here are the edited files for phpBB 3.2.1
Download: https://www.supportforum.be/private/scripts/board3.zip
Solidjeuh
Post by Solidjeuh »
Ok I updated the files for the last time.
I now included ALL fixes that I could find.
Seems to work perfect on my 3.2.2 board.
Here is a list of the changes..
Solidjeuh
Post by Solidjeuh »
Error in he url, I"m sorry. Previous post is ok now! :)
mela030
Post by mela030 »
Since update to the latest phpbb version 3.2.2 the portal page is not shown anymore.
Does anyone else has this problem?
MyLady
Sponsor
phpBB.de User: Scanialady
phpBB.com User: Scanialady
Post by MyLady »
no, I can not confirm. Portal is ok on my test board after the first update test to 3.2.2
Do you have deactivated all extensions before update?
Solidjeuh
Post by Solidjeuh »
mela030 wrote: 6. February 2018 14:08 Since update to the latest phpbb version 3.2.2 the portal page is not shown anymore.
Did you overwrite the .htaccess ?Then you are maybe missing this in the file:
Also don't forget to update the portal, you can use my files if you want:
viewtopic.php?f=71&t=11270&start=30#p37583
Solidjeuh
Post by Solidjeuh »
Updated the files, I forgot to add the Paypal module fix.
Board3 Portal tested on phpBB 3.2.7.RC.1
Download: https://www.solidjeuh.be/scripts/board3.zip
* Converted files to Twig Syntax
* Added missing bracket (Paypal fix)
https://www.board3.de/posting.php?mode= ... 70#pr37492
* Update to phpBB 3.2.1
http://reyno41.bplaced.net/phpbb/viewto ... p=788#p788
* Permissions fix:
https://github.com/board3/Board3-Portal/pull/650/files
* Reduce caching time fix:
https://github.com/board3/Board3-Portal/pull/667/files
* LATEST_NEWS - Too mach space for column 'LAST_POST'
https://www.board3.de/viewtopic.php?sty ... 063#p36241
Voice4Vision
phpBB.de User: Voice4Vision
phpBB.com User: Voice4Vision
Post by Voice4Vision »
Hey Solidjeuh, I am getting the following error when attempting to add a new module.
{"MESSAGE_BODY":"\t<form id=\"acp_portal_modules\" method=\"post\" action=\".\/..\/adm\/index.php?i=-board3-portal-acp-portal_module&sid=7e0204dd3e086f9de67ce2420a87495b&mode=modules\">\n\t\t<fieldset>\n\t\t\t<dl>\n\t\t\t\t<dt><label for=\"module_classname\" style=\"display: inline;\">Choose module:<\/label><br \/><span>Choose a module from the drop-down list<\/span><\/dt>\n\t\t\t\t<dd><select name=\"module_classname\" id=\"module_classname\"><option value=\"\\jv\\arcade_b3portal\\modules\\arcade_center_best_rated_games\">Arcade - Best rated games<\/option><option value=\"\\jv\\arcade_b3portal\\modules\\arcade_latest_highscores\">Arcade - Latest highscores<\/option><option value=\"\\jv\\arcade_b3portal\\modules\\arcade_longest_highscores\">Arcade - Longest held highscores<\/option><option value=\"\\jv\\arcade_b3portal\\modules\\arcade_center_new_games\">Arcade - Newest games<\/option><option value=\"\\jv\\arcade_b3portal\\modules\\arcade_center_random_games\">Arcade - Random games<\/option><option value=\"\\jv\\arcade_b3portal\\modules\\challenge_leaders\">Arcade challenge - leaders<\/option><option value=\"\\jv\\arcade_b3portal\\modules\\arcade_leaders\">Arcade leaders<\/option><option value=\"\\jv\\arcade_b3portal\\modules\\tour_leaders\">Arcade tournament leaders<\/option><option value=\"\\board3\\portal\\modules\\attachments\">Attachments<\/option><option value=\"\\board3\\portal\\modules\\custom\">Custom Block<\/option><option value=\"\\board3\\portal\\modules\\forumlist\">Forumlist<\/option><option value=\"\\board3\\portal\\modules\\announcements\">Global announcements<\/option><option value=\"\\board3\\portal\\modules\\news\">Latest news<\/option><option value=\"\\board3\\portal\\modules\\donation\">PayPal donations<\/option><option value=\"\\board3\\portal\\modules\\poll\">Poll<\/option><option value=\"\\jv\\arcade_b3portal\\modules\\arcade_online_playing_games\">Who is playing in the arcade?<\/option><\/select><\/dd>\n\t\t\t<\/dl>\n\n\t\t\t<p class=\"submit-buttons\">\n\t\t\t\t<input class=\"button1\" type=\"submit\" id=\"submit\" name=\"submit\" value=\"Submit\" \/>&nbsp;\n\t\t\t\t<input class=\"button2\" type=\"reset\" id=\"reset\" name=\"reset\" value=\"Reset\" \/>\n\t\t\t\t<input type=\"hidden\" name=\"creation_time\" value=\"1525307165\" \/>\n<input type=\"hidden\" name=\"form_token\" value=\"36cb1008da0b229963aff0b64eacb0679e86a703\" \/>\n<input type=\"hidden\" name=\"add_column\" value=\"2\" \/>\n\n\t\t\t<\/p>\n\t\t<\/fieldset>\n\t<\/form>\n\n","MESSAGE_TITLE":"Add module","MESSAGE_TEXT":"Add module","YES_VALUE":"Submit","S_CONFIRM_ACTION":".\/..\/adm\/index.php?i=-board3-portal-acp-portal_module&sid=7e0204dd3e086f9de67ce2420a87495b&mode=modules","S_HIDDEN_FIELDS":"<input type=\"hidden\" name=\"add_column\" value=\"2\" \/>\n"}
This has happened with no additional extensions on a fresh install (root) of phpBB 3.2.2(prosilver). This error message appears regardless of what module I try to add or what position I try to add it. Earlier today, I deleted my sessions and it worked again. However the error came back, but now deleting my sessions has no effect regarding the error message.
Do you have any idea what could be going on?
Any and all assistance would be greatly appreciated!
Thank you,
Voice4Vision
This: arcade_b3portal is not part of the portal.
Voice4Vision
Same error type....different install. Only 20 minutes after installation.
{"MESSAGE_BODY":"\t<form id=\"acp_portal_modules\" method=\"post\" action=\".\/..\/adm\/index.php?i=-board3-portal-acp-portal_module&sid=a7d6c6dc3c9d0a5a9db9f0a15cc11283&mode=modules\">\n\t\t<fieldset>\n\t\t\t<dl>\n\t\t\t\t<dt><label for=\"module_classname\" style=\"display: inline;\">Choose module:<\/label><br \/><span>Choose a module from the drop-down list<\/span><\/dt>\n\t\t\t\t<dd><select name=\"module_classname\" id=\"module_classname\"><option value=\"\\board3\\portal\\modules\\attachments\">Attachments<\/option><option value=\"\\board3\\portal\\modules\\custom\">Custom Block<\/option><option value=\"\\board3\\portal\\modules\\forumlist\">Forumlist<\/option><option value=\"\\board3\\portal\\modules\\announcements\">Global announcements<\/option><option value=\"\\board3\\portal\\modules\\news\">Latest news<\/option><option value=\"\\board3\\portal\\modules\\donation\">PayPal donations<\/option><option value=\"\\board3\\portal\\modules\\poll\">Poll<\/option><\/select><\/dd>\n\t\t\t<\/dl>\n\n\t\t\t<p class=\"submit-buttons\">\n\t\t\t\t<input class=\"button1\" type=\"submit\" id=\"submit\" name=\"submit\" value=\"Submit\" \/>&nbsp;\n\t\t\t\t<input class=\"button2\" type=\"reset\" id=\"reset\" name=\"reset\" value=\"Reset\" \/>\n\t\t\t\t<input type=\"hidden\" name=\"creation_time\" value=\"1525392589\" \/>\n<input type=\"hidden\" name=\"form_token\" value=\"5b1fe6412826ceb7e96b884d3bb40241187e5031\" \/>\n<input type=\"hidden\" name=\"add_column\" value=\"2\" \/>\n\n\t\t\t<\/p>\n\t\t<\/fieldset>\n\t<\/form>\n\n","MESSAGE_TITLE":"Add module","MESSAGE_TEXT":"Add module","YES_VALUE":"Submit","S_CONFIRM_ACTION":".\/..\/adm\/index.php?i=-board3-portal-acp-portal_module&sid=a7d6c6dc3c9d0a5a9db9f0a15cc11283&mode=modules","S_HIDDEN_FIELDS":"<input type=\"hidden\" name=\"add_column\" value=\"2\" \/>\n"}
CURRENT EXTENSIONS INSTALLED
Enabled Extensions
About us 2.1.2
Advanced BBCode Box 3.2.0
Advanced Profile Fields Pack 1.0.3
Ajax Base 2.0.0
AJAX Registration Check 1.0.1
AJAX Registration check 1.0.0
AJAX Userinfo 1.0.0
Annual Stars 1.0.2
Application Form 1.0.7
Auto Groups 2.0.0
Avatars on Memberlist 2.0.0
Ban Hammer 1.0.5
Birthday Cake 1.0.2
Board3 Portal 2.1.0
Upload Extensions 3.2.0-dev
Disabled Extensions
VigLink 1.0.3
I have tried PHP Version 5.5.38, 5.6.35, 7.0.29, 7.1.16, and 7.2.4 all with the same result. Cache has been cleared/deleted from server and browser as well as multiple fresh installs. I have used 2 versions of phpBB 3.2.2 original download from https://www.phpbb.com and Auto-installer from my host.
Solidjeuh
Post by Solidjeuh »
Can't reproduce the error.. All works here.
Voice4Vision
Solidjeuh wrote: 4. May 2018 02:31 Can't reproduce the error.. All works here.
Excellent support!
Thanks for your effort.
Solidjeuh
Post by Solidjeuh »
Voice4Vision wrote: 4. May 2018 02:43
Excellent support!
It's not my extension, can only tell you that all works on my forum :ugeek:
