Problem with forum in portal
Kilzin
phpBB.de User: Kilzin
phpBB.com User: Kilzin
Post by Kilzin »
Your Portal Version: 1.0.4
Boardlink: http://www.quantumguild.info
When I install board3Portal got a problem with forum in portal
Cannot find any solve problem!
As you can see this the image:
How I can solve problem?
Re: Problem with forum in portal
This is a typical problem for small prosilver based Styles. Sadly theres nothing you can do to fix this. We use the forumlist_body from the Board to get this list. And in prosilver based Styles with a small fixed width theres not enough space, so the list will crushed...
So the only thing you can do, is to set a higher width if your style support it.
Kilzin
Post by Kilzin »
Thank for reply. I did post in phpbb style for this problem. Wait and get answer....
EDIT: I got the answer by styler:
I believe that the board3 portal have a speciel setting for narrow styles.
Ask in the board3 portal topic if you cant find it.
Does you have special setting for narrow styles? If yes, how I can fix it? Template is SE Pro with based Prosilver.
Yes, we have a setting for narrow Styles. But it will only affect our own blocks "news" and "announcements".
Since we just include the forum index, we cant control this block.
For news and announcement, go to acp and disable Display the number of replies and views:
Explanation:
This setting pertains to the compact block.
When Yes, the number of replies and views are shown in 2 extra columns. When No, replies and views will be shown beside the forum name. Select No if you have problems with the display of the extra columns due to the extra width required.
