probleme on ACP
daniel25000
probleme on ACP
Post by daniel25000 »
PHP Version: phpbb3
hello my probleme is incredible:
portal function ok
forum ok
is big bug on ACP double portail.....? :o
clean up cookies cache templates etc. ...
thanks for help
daniel
ayu
Re: probleme on ACP
Post by ayu »
i have the same problem with phbb 3.0.7pl1
Re: probleme on ACP
Check your language files, they might be corrupted. Also try replacing your includes/functions_module.php with the one from the phpBB package.
ayu
Re: probleme on ACP
Post by ayu »
i have check no error
i have replace includes/functions_module.php with the one
but you don't have change
Re: probleme on ACP
Just try uploading the language files from the portal archive again. This usually doesn't happen unless your language files are old or corrupted.
ayu
Re: probleme on ACP
Post by ayu »
ok i try this solution i hope
ayu
Re: probleme on ACP
Post by ayu »
same problem
