Disabling one of the columns transferred blocks do not show.
contiw
phpBB.com User: contiw
Post by contiw »
By copying blocks from the left to the right column then disabling left column in the Portal Admin, I cannot get the copied block to show.
Set leftColumn back ON in acp portal admin and
set var S_LEFT_COLUMN to "false" manually, in portal_body.html.
Would be nice to find out where the problem is, but callow nub here ... Please advise. Thank you.
Re: Disabling one of the columns transferred blocks do not s
I updated the instructions for moving blocks:
Knowledge Base: Moving blocks / change order
A bit down the page, you will find instructions on what you have to do when you are moving a block from one side column to the other one.
contiw
Post by contiw »
Got it, Marc. Thank You.
If the weather and the authorities permit,
please do a drag-and-drop UI for columns manipulations. :lol:
Thanks again. Hve a nice weekend.
