portal link not showing up
Jonasty
phpBB.com User: jonasty
Post by Jonasty »
Boardlink: http://www.retrohelpers.co.cc
installed the portal with easymod, dutch language
searched the CMS pages of the portal, but it's probably in one of the many files
screen of the problem:
normally I should get portal < forumoverzicht
please help asap, thanks
Re: portal link not showing up
open overall_header.html
find:
<li class="icon-home"><a href="{U_INDEX}" accesskey="h">{L_INDEX}</a> <!-- BEGIN navlinks --> <strong>&#8249;</strong>
find in line:
in line add after:
Knowledge Base: Changes to forums styles
Jonasty
Post by Jonasty »
thank you very much for te fast response
works now
Regards
helwoe
Post by helwoe »
I have the same problem as this person. No portal link anywhere on the portal page?!?
Tried all that has been suggested with no good results.
Re-checked installation again and cant figure this out.
Using Rockettheme's Refraction theme (subsilver based I believe)
(http://www.thelegionhq.com)
helwoe
You have already asked that in a different topic, so please don't spam around.
helwoe
Post by helwoe »
Actually two separate topics.
Portal PAGE not showing up.
Portal LINK not showing.
But I'll keep it to one post as you wish.
helwoe
Jonasty
Post by Jonasty »
helwoe wrote:Actually two separate topics.
helwoe
if you look closely, this topic has been answered already...
why don't you just use the answer?
it worked for me (I'm the topic starter all the way back then...)
Regards, Jonas
helwoe
Post by helwoe »
I'm glad it worked for you.
However it is not working for me despite my best efforts these last few days.
Open to any and all suggestions.. ;)
helwoe
Jonasty
Post by Jonasty »
helwoe wrote:I'm glad it worked for you.
helwoe
does it work with the standard styles (sub/prosilver)?
if it does, look for the code in the solution above in one of the files inside that theme, instead overall_header; not sure that this will work but I think it's worth a try
Best Regards, Jonas
helwoe
Post by helwoe »
Best Regards, Jonas
Thanks for your reply.
Wow, it does work in the prosilver theme?!?
But in the refraction theme still no portal link.
EDIT: just noticed the portal link is at the bottom of the page.
This theme is based on prosilver, and I applied all the edits changes/file copies to the prosilver & refraction folders and files. However the styles/refraction/template/overall_header.html I could not find the lines noted in the instructions..
Looking for this:
Nothing even close to the above line.
Looking for this:
Found & Edited:
<!-- IF REF_MENUPOSITION == full -->
After changes (clear cache, refresh templates, themes, images (even clearing cache folder) I get this error:
Parse error: syntax error, unexpected $end in /home/content/t/h/e/thelegionadmin/html/phpbb3/cache/tpl_refraction_overall_header.html.php on line 459
Looking for this:
Found:
But the needed <--ELSE-->> statement is already there?!?
So thats where I'm at... I'm sure it's a matter of adding code but I'm lost trying to figure it out.
Thanks again.
helwoe
Re: portal link not showing up[SOLVED]
Post by helwoe »
solved
in styles/refraction/overall_header.html
added this:
Here:
<!-- IF U_PORTAL --><a href="{U_PORTAL}">{L_PORTAL}</a> &#187; <!-- ENDIF --><a href="{U_INDEX}" accesskey="h" class="pathway">{L_INDEX}</a> <!-- BEGIN navlinks --><img src="{T_THEME_PATH}/images/arrow.png" alt=""  /><span class="no-link"><a href="{navlinks.U_VIEW_FORUM}">{navlinks.FORUM_NAME}</a></span><!-- END navlinks --></span>
</div><!-- ENDIF -->
Moved it to the far left for left menu item.
helwoe
Jonasty
Post by Jonasty »
helwoe wrote:solved
added this:
Here:
helwoe
glad for you :)
Best Regards
