Your Portal Version: 1.0.2
Boardlink: http://www.portalfpg.com
PHP Version: 5.2.3
Upgraded the Portal from the RC version to 1.0.2
Checked the settings in the acp, but found nothing strange.
I don't really know if that's the reason, but after upgrading the portal, it does not display the latest global annoucements and news block. What can this be?
Also I'm getting a SQL Error:
Erro Geral
SQL ERROR [ mysql4 ]
Duplicate entry 'record_online_users' for key 1 [1062]
And I don't know if it has anything to do with the portal, but it's getting me crazy. All I have to do, is to edit the field is_dynamic, in the phpbb_config table, changing from '0' to '1'. And the site runs again normally...
Help
Where is the news and the latest annoucements block
Re: Where is the news and the latest annoucements block
Something seems to have gone wrong during the. I suggest you re-upload the install dir, browse to install_portal/install.php hit "Uninstall" on the left hand menu then browse back to install_portal/install.php and install it afresh. Unfortunately you will lose your portal settings but it is the best I can suggest I'm afraid.
I've uninstalled the portal like you said, but when tryied to install I've got this message:
Language file english/common.php couldn't be opened.
Even if I type the normal URL (www.portalfpg.com), I get the same error, so now the forum is down
I've checked the language files, uploaded new ones, checked the database config...
Help pleaseeeeeeeee!!!!
