Portal button messed up and prosilver style is diff to demo
Stam
Post by Stam »
Your Portal Version: 1.0.3
Boardlink: http://stam.thesmokylounge.com/forums/portal.php
Nothing. It installed perfectly
Nothing I have no idea, sorry :(
Hi looking at my board index my portal link is sort of messed up, and also my portal page almost looks different to the demo version of subsliver. The icons are different for the menu etc..
Can anyone else notice that? Also if I wanted to use subsilver special edition as my style instead of subsilver how would go about that? They are very alike so I assume it wouldnt be too hard? Thanks very much!
Ice
Re: Portal button messed up and prosilver style is diff to demo
Post by Ice »
You haven't refreshed the theme, ACP -> Styles -> Themes -> prosilver -> refresh.
For subsilver2 look in the contrib folder for the install file.
Stam
Post by Stam »
Oh brilliant that fixed the portal style difference but the portal button on the board index is still messed up. I assume i made a mistake in the overall_header perhaps?
Ice
Post by Ice »
Yeh, the portal link needs to go before the board link. IE bwtween <li class="icon-home"> and <a href=
Stam
Post by Stam »
<li class="icon-home"><a href="{U_INDEX}" accesskey="h">{L_INDEX}</a> <!-- BEGIN navlinks --> <strong>&#8249;</strong> <!-- IF U_PORTAL --><a href="{U_PORTAL}">{L_PORTAL}</a> &#187; <!-- ENDIF --> <a href="{navlinks.U_VIEW_FORUM}">{navlinks.FORUM_NAME}</a><!-- END navlinks --></li>
I put it in between those but nothing has changed, i even refreshed the page. Thats what the line looks like.
Ice
Post by Ice »
In the install file it says BEFORE the index link.
For example:
<li class="icon-home"><!-- IF U_PORTAL --><a href="{U_PORTAL}">{L_PORTAL}</a> &#187; <!-- ENDIF --><a href="{U_INDEX}" accesskey="h">{L_INDEX}</a> <!-- BEGIN navlinks --> <strong>&#8249;</strong>  <a href="{navlinks.U_VIEW_FORUM}">{navlinks.FORUM_NAME}</a><!-- END navlinks --></li>
Stam
Post by Stam »
Still the same for some reason
Thats what I have and yet its still the same
Just looking, the footer is the same aswell.
Ice
Post by Ice »
Have you refreshed the cache after making style changes?
Stam
Post by Stam »
Ok a refresh of everything(images, templates etc..) solved it! Thanks for the help!
Stam
Post by Stam »
I am having one problem now though, the style seems to be stuck on prosilver and wont change to prosilver special edition even though, its the default style its still showing prosilver and thats not the default style!
I've deactivated it, refreshed everything possible, cleared cookies everything. Prosilver special edition did work earlier! The preview of prosilver special edition works perfectly shows everything.
But it just seems like its stuck on prosilver, ive tried all the basics to deactivate reactivate change the defaults around everything!
Change your own style to prosilver SE in your UCP. ;)
Ice
Post by Ice »
You need to change the style of the default "Anonymous" user.
Stam
Post by Stam »
Marc wrote:Change your own style to prosilver SE in your UCP. ;)
I did that, it worked, but that'll be only for me though, everyone else will still prosilver? I also did over ride userstyle
Ice wrote:You need to change the style of the default "Anonymous" user.
How would I do that? Cheers.
