Icons dont show
rebeldama
Icons dont show
Post by rebeldama »
Boardlink: http://www.rebeldama.com/forum/portal.php
I have done all here : portal_docs/install.xml
double checked installation prosedyre.
I installed the Portal and got two issues.
1. the small icons in the blocks do not show in the portal
Is there a path I have missed? the folder is placed: styles/prosilver/imageset/portal
2. the blocks are a bit out of place
This I belive is an easy adjustment, but where do I do that?
I have already tryed the "Left and right column width settings", but the recommended 180 is the best otherwise the text go outside the block.
See: http://www.rebeldama.com/forum/portal.php
Please if someone can help.
Ice
Re: Icons dont show
Post by Ice »
The style your using seems to be based on subsilver2 so you might want to try using the subsilver2 board3 templates rather than prosilver.
rebeldama
Re: Icons dont show
Post by rebeldama »
Thank you for reply :)
I have now deactived prosilver and activated subsilver2.. But nothing happen..
Is there special templates I should download?
All the altering from portal_docs/install.xml is in prosilver, is there anything I should do in subsilver2 (and where can I find it)?
When I installed board 3 first time, there was some editing in subsilver2 the mod did not find. Since I used prosilver I forced the installation (yes, I know this was not smart move). (I uploaded to store/mods)
But I have now uninstalled board 3 and reinstalled it.. (this time I did not automod the installation, but placed board3 in root)
the icons worked this time, but now I lost the portal home icon in the forum index site ->
And the font size in the portal is 100% too big ->
I appoligize for my bad english, but I hope you understand. And may have some answers for me :)
Ice
Re: Icons dont show
Post by Ice »
Copy the files in subsilver2 directory the board3 zip file to the acidtechred style folder, then refresh cache.
rebeldama
Re: Icons dont show
Post by rebeldama »
Thank you very much :) :) :) :) :) :)
This I would never have figured out by my self!!
Only two things left before this is perfect..
The font size and the missing portal home icon in the forum index..
Ice
Re: Icons dont show
Post by Ice »
You'll have to do the subsilver2 edits to the acidtechred files, the instructions are in the contrib directory.
As for the font size I don't see any difference?
rebeldama
Re: Icons dont show
Post by rebeldama »
Thank you again :)
For the font size, I found out that it is made for IE7, and I have IE8..
(in IE8 the font size is double up from normal size)
The font is normal in FF too..
Is there an update for IE8?
Ice
Re: Icons dont show
Post by Ice »
Uh I'm not sure, sorry. You could try the styles forum?
rebeldama
Re: Icons dont show
Post by rebeldama »
Yes, I can do that :)
Thank you for all the help :) :)
Re: Icons dont show
You can use an adapted config... maybe this wil help you: http://board3.de/viewtopic.php?f=42&t=2083
(check the demo as first)
