Mod version check error..
Current Version: 2.0.2
Released: 2013-10-27
CrashTester
Post by CrashTester »
Hi. I would like to install Portal on my site and it tells me that I need to have Mod Version Check installed first, which I have installed, yet when I run the installation via Automod the check to confirm its says;
root/adm/mods/board3_portal_check_version.php 	adm/mods/board3_portal_check_version.php 	Error
Mod version check details are as follows;
MOD Version Check
Version: 1.0.2
Path: ./../store/mods/mod_version_check/MOD_Version_Check.xml
Installation time: Mon Sep 12, 2011 1:29 am
Description: Adds a version check to your board to keep up to date on all your mods
How can I get around this without doing a Force Install? Thanks.
CrashTester
Re: Mod version check error..
Does anyone have any suggestions on this before I force the install? Thanks.
Make sure that folder exists and if it does then also check that you can copy files there.
CrashTester
Thanks Marc, I will try that and let you know how it goes.
