Not allowed extension
Current Version: 2.0.2
Released: 2013-10-27
KillBill
phpBB.com User: KillBill.
Post by KillBill »
[phpBB Debug] PHP Notice: in file /portal/includes/functions_upload.php on line 159: Undefined variable: mod_dir
Otherwise, congratulations on this portal engine, very nice work.
KillBill
Upload new module
Post by KillBill »
Acp/mods/portal/Upload module
The field is empty then an error occurs.
[phpBB Debug] PHP Notice: in file /portal/includes/functions_upload.php on line 58: Undefined index: NO_UPLOAD_FILE
Other:
A default mod directory structure is as follows.
  • contrib
  • root
  • install.xml
  • license.txt
  • modx.prosilver.en.xsl
In this case, the module will upload error add. (Module corrupted)
So I propose the following change.
find
                    // make sure we set $mod_dir to the correct folder after the above step
                    $mod_dir = (isset($new_mod_dir)) ? $new_mod_dir : $mod_dir;
after add
                    // check root folder
                    $relative_mod_dir = (file_exists("$mod_dir/root")) ? "$mod_dir/root" : $mod_dir;
find
                    $iterator = new RecursiveIteratorIterator(new RecursiveDirectoryIterator($mod_dir)); // requires PHP 5
replace
                    $iterator = new RecursiveIteratorIterator(new RecursiveDirectoryIterator($relative_mod_dir)); // requires PHP 5
find
                    foreach($iterator as $cur_file)
after add
                        if (in_array($cur_file->getFilename(), array('.', '..', 'license.txt')))
                            continue;
find
                        $cur_path = str_replace($mod_dir . '/', '', $cur_path);
                        $cut_pos = strpos($cur_path, '/');
                        // Only allow files in adm, language, portal and styles folder
                        if(!in_array(substr($cur_path, 0, $cut_pos), array('adm', 'language', 'portal', 'styles')) && $cur_file->getFilename() != 'license.txt')
replace
                        $cur_path = str_replace($relative_mod_dir . '/', '', $cur_path);
                        if (!in_array(substr($cur_path, 0, $cut_pos), array('adm', 'language', 'portal', 'styles')))
find
                            $actions['NEW_FILES'][$mod_dir . '/' . $cur_path] = $phpbb_root_path . $cur_path;
replace
                            $actions['NEW_FILES'][$relative_mod_dir . '/' . $cur_path] = $phpbb_root_path . $cur_path;
So the upload modul is successful.
Other:
        @chmod($to, octdec(0644));
deleted
//@chmod($to, octdec(0644));
or changed
@chmod($to, 0644);
The files attribute is too small, so the portal can not display icon image.
Files attributes after uploading = 420
MyLady
Sponsor
phpBB.de User: Scanialady
phpBB.com User: Scanialady
Re: Not allowed extension
Post by MyLady »
I've noticed that too
KillBill
Post by KillBill »
If no new module and click add module
[phpBB Debug] PHP Warning: in file [ROOT]/includes/acp/acp_portal.php on line 845: array_multisort() [function.array-multisort]: Argument #1 is expected to be an array or a sort flag
