http://factor8guild.com/phpBB3/
Installed by following these directionsviewtopic.php?f=47&t=3853&p=24500&hilit ... ray#p24500
Now I seem to be missing block borders and colors. Must have mucked up somewhere.
I've double checked and can't find my mistake. Any suggestions would be appreciated.
Thanks!
Hermes Gray block issue.
- phpBB.com User: SDB8
Re: Hermes Gray block issue.
You must copy the files subsilver2 portal.StuDaBaker wrote:http://factor8guild.com/phpBB3/
Installed by following these directions viewtopic.php?f=47&t=3853&p=24500&hilit ... ray#p24500
Thanks!
to: styles/hermes/template/portal/*.*
to: styles/hermes/theme/images/portal/*.*
Thanks for quick reply, those folders and files are in place. I installed them initially, and re-installed them after your reply to make sure, no difference.
You should read everything. Click on:StuDaBaker wrote:Thanks for quick reply, those folders and files are in place. I installed them initially, and re-installed them after your reply to make sure, no difference.
open: styles/hermes/template/portal/_block_config.html
_block_config.html for Hermes / hermes_gray / hermes_green
Refresh your Styles:
Thanks again, and I beg for your patience with me, I am new to phpbb and php.
I followed this english step by step install guide (and backed up original files before editing), including the _block_config.php
I then re-did the installation using the backed up files for editing and uploading, prior to making my first post here.
The only thing I cannot read there is the
Are you thinking I missed something along the way and should re-attempt installation following this guide again, or is there some important information in the DIY Instructions: Knowledge Base: Changes to forums styles that I'm missing because I can't read german?
which links to a topic in German.DIY instructions: Knowledge Base: Changes to forums styles
In the guidance they need to click on:
----->[+] ENGLISH
The style of "Hermes" is based on subsilver2, so they need to upload the files subsilver2 portal for their style.
----->[+] ENGLISH
Thank you, but yes, I realize that I need to open the guide in ENGLISH. That is the guide I have been following.
the subsilver2 files have been uploaded to the hermes gray directory
Thank you for your efforts, I deleted the portal folders from templates and themes, then reuploaded and changed the _block_config.html and it is now working. Must have missed something along the way.
Thanks, again.
and thanks for the Board3 portal!
Thanks, again.
