Portal has vanished
Current Version: 2.0.2
Released: 2013-10-27
JD2K
phpBB.com User: D2K
Portal has vanished
Post by JD2K »
I have PHPbb installed under /forum directory, the portal was working great. I decided to redirect so the website works without /forum at the end: www[dot]d2kgaming[dot]net but since then the portal has vanished. Any ideas?
Re: Portal has vanished
Make sure your .htaccess is edited as instructed by install.xml.
JD2K
phpBB.com User: D2K
Post by JD2K »
.htaccess file has changed.
Where should I add this? because when I add it after "common.php' website gets an error:
<![CDATA[DirectoryIndex portal.php index.php index.html index.htm]]>
This is the .htaccess file as of now:
DirectoryIndex index.php portal.php index.html index.htm
#<IfModule mod_rewrite.c>
#RewriteEngine on
#</IfModule>
<Files "config.php">
Order Allow,Deny
Deny from All
</Files>
<Files "common.php">
Order Allow,Deny
Deny from All
</Files>
JD2K
phpBB.com User: D2K
Post by JD2K »
update: Portal works if I type it in manually : d2kgaming[dot]net/portal.php
I had my website redirected from d2kgaming[dot]net/forum to d2kgaming[dot]net, portal directory is under /forum
Is this a simple .htaccess redirect issue?
That's your problem. portal.php needs to be in front of index.php.
JD2K
phpBB.com User: D2K
Post by JD2K »
I just tried:
Still no luck.
JD2K
phpBB.com User: D2K
Post by JD2K »
Problem fixed, .htaccess file that I needed to change was in the /forum directory which looked like this:
I changed it to
Problem fixed.
Thanks MARC :)
