Newbi HTML Question
Marman
Newbi HTML Question
Post by Marman »
I need some help with spacing. If you check out my portal: http://www.sadisticoldbastards.com/phpBB3/portal.php you will see that the server monitors are butted right up against each other.
Is there a way to put a space between them? I have tried adjusting the frameborder in the code with no luck, code listed below:
Thanks,
<center>
<!-- Start GameTracker Banner -->
<iframe src="http://cache.www.gametracker.com/components/html0/?host=208.43.14.75:28960&bgColor=333333&titleBgColor=222222&borderColor=555555&fontColor=CCCCCC&titleColor=FF9900&linkColor=FFCC00&borderLinkColor=222222&showMap=1&showCurrPlayers=1&showTopPlayers=0&showBlogs=0&width=200&height=421" frameborder="20" scrolling="no" width="200" height="421"></iframe>
<!-- End GameTracker Banner -->
<iframe src="http://cache.www.gametracker.com/components/html0/?host=208.43.14.82:28960&bgColor=333333&titleBgColor=222222&borderColor=555555&fontColor=CCCCCC&titleColor=FF9900&linkColor=FFCC00&borderLinkColor=222222&showMap=1&showCurrPlayers=1&showTopPlayers=0&showBlogs=0&width=200&height=421" frameborder="20" scrolling="no" width="200" height="421"></iframe>
</center>
PeterS
phpBB.de User: PeterS
phpBB.com User: PeterS
Re: Newbi HTML Question
Post by PeterS »
Hi marman,
add &nbsp; for a space, you can repeat this
or <br /> for a line break
Peter
Marman
Post by Marman »
Thanks so much, worked great.......
Return to “Styles Support”
