How do I know what styles support the portal?
gwmara
Post by gwmara »
Your Portal Version: 1.0.4
Boardlink: http://www.gwmara.com
PHP Version: 3.0.6
It's not really a problem like that.
No, I have no knowledge at all. We had everything installed for us.
I've downloaded, installed and try out a lot of different themes. What should I look for to make sure it support the portal? We have ajax chat and arcade installed as well and they don't seem to show up on most templates
*Edit sorry if I posted this in the wrong forum :oops:
Re: How do I know what styles support the portal?
A lot of templates are more or less compatible with Board3 Portal. The most important part you should look for is the width. Some fixed width styles have a small width, which causes errors with Board3 Portal (i.e. boxes stick out of the normal forum wrap). I suggest you use styles with a dynamic width or at least width a decent width to work with.
Here is a list with a few Styles i already adapted. (with demolinks)
gwmara
Post by gwmara »
I've downloaded some of them but got this error:
template->_tpl_load_file(): File ./styles/AeroRed/template//portal/portal_body.html does not exist or is empty
Didn't see them on this page so I guess the error is because I didn't change the _block_config.html
<!--version $Id: _block_config.html v1.0.4 adapted by: Franki $ //-->
<!-- DEFINE $LR_BLOCK_H_L = '<table width="100%" border="0" cellpadding="0" cellspacing="0"><tr><td width="18" height="18"><img src="./styles/AeroRed/theme/images/tl.png" width="18" height="18" alt="" /></td><td height="18" style="background:url(./styles/AeroRed/theme/images/tm.png);"></td><td width="18" height="18"><img src="./styles/AeroRed/theme/images/tr.png" width="18" height="18" alt="" /></td></tr><tr><td width="18" style="background:url(./styles/AeroRed/theme/images/ml.png);"></td><td><table class="tablebg" cellspacing="0" width="100%"><tr><th><span style="float: left">' -->
<!-- DEFINE $LR_BLOCK_H_R = '</span></th></tr></table>' -->
<!-- DEFINE $LR_BLOCK_F_R = '</td><td width="18" style="background:url(./styles/AeroRed/theme/images/mr.png);"></td></tr><tr><td width="18" height="18" align="right"><img src="./styles/AeroRed/theme/images/bl.png" width="18" height="18" alt="" /></td><td height="18" style="background:url(./styles/AeroRed/theme/images/bm.png);"></td><td width="18" height="18"><img src="./styles/AeroRed/theme/images/br.png" width="18" height="18" alt="" /></td></tr></table>' -->
<!-- Config for the center blocks // -->
<!-- DEFINE $C_BLOCK_H_L = '<table width="100%" border="0" cellpadding="0" cellspacing="0"><tr><td width="18" height="18"><img src="./styles/AeroRed/theme/images/tl.png" width="18" height="18" alt="" /></td><td height="18" style="background:url(./styles/AeroRed/theme/images/tm.png);"></td><td width="18" height="18"><img src="./styles/AeroRed/theme/images/tr.png" width="18" height="18" alt="" /></td></tr><tr><td width="18" style="background:url(./styles/AeroRed/theme/images/ml.png);"></td><td><table class="tablebg" cellspacing="0" width="100%"><tr><th><span style="float: center">' -->
<!-- DEFINE $C_BLOCK_H_R = '</span></th></tr></table>' -->
<!-- DEFINE $C_BLOCK_F_R = '</td><td width="18" style="background:url(./styles/AeroRed/theme/images/mr.png);"></td></tr><tr><td width="18" height="18" align="right"><img src="./styles/AeroRed/theme/images/bl.png" width="18" height="18" alt="" /></td><td height="18" style="background:url(./styles/AeroRed/theme/images/bm.png);"></td><td width="18" height="18"><img src="./styles/AeroRed/theme/images/br.png" width="18" height="18" alt="" /></td></tr></table>' -->
<!-- DEFINE $BLOCK_DISTANCE = '0' -->
In what file and where do I put the code? Or what am I doing wrong?
Depending on wether your style is based on prosilver or subsilver2, you have to also upload the correct template and theme files for your style. For example, if your style is based on subsilver2, like AeroRed, upload the portal-files for subsilver2 to AeroRed.
gwmara
Post by gwmara »
Should the portal be updated before adding another template?
I recommend updating to Board3 Portal 1.0.5, no matter what you want to do.
Return to “Styles Support”
