prosilver_se issues with board3 portal
Till
Post by Till »
Your Portal Version: 1.0.6
Boardlink: http://campusvgf.ca
portal appeared fine before, after installing prosilver_se, portal does not appear right.
some of the solution from the forum ( viewtopic.php?style=1&f=36&t=4093 ) but it didn't work, (i have backups of the file i edited).
I'm having a problem installing the prosilver_se theme and having the portal page display right. (board link should show you what's going on. i'd also like to know what to do to to make the board index link (circled here: http://192.168.0.102/widgebo/titlebar.png ) also contain a link to the portal like it does in the plain prosilver style.
Re: prosilver_se issues with board3 portal
You must edit the style as if it is "prosilver".
Then do this:----> viewtopic.php?f=44&t=2878
Till
Post by Till »
that seemed to work, i guess it was nano breaking long lines into multiple lines that was causing the problems.
awaismastimp1
phpBB.de User: awaismastimp1
phpBB.com User: awaismastimp1
Post by awaismastimp1 »
its working but in my forum icons aren't showing yet
help plz
visit my forum
www.mufasa.vacau.com
awaismastimp1 wrote:its working but in my forum icons aren't showing yet
help plz
visit my forum
http://www.mufasa.vacau.com
You have not loaded all the portal-files in the style high! ;)
awaismastimp1
help plz
visit my forum
but can you which files i have to put in my style folder through ftp client(Filezilla) although in prosilver folder files of portal are present and prosilver is working well...but how to do with prosilver se which folder i have to paste so that icons can be shown
awaismastimp1
plxz help
Return to “Styles Support”
