Remove Portal Images?
easyconv
Post by easyconv »
PHPBB: v.3.0.10
Style: Lucid Lime (theme: reckless_red)
Portal: [BETA] Board3 Portal 2.0.0b1
The images don't display correctly with my theme.(even if they did I'd still want them removed)
But the problem is, when I remove them from the ACP in the portal mod, the red line that sperates the header and the body of the block is broken.
I realize this is hard to imagine so I've included a picture.
The top block is with the images.
And the bottom is when I remove it.(notice the incomplete red line)
And to be clear I want to remove all portal images.
I've even tried physically deleting them, but it caused the same display problems.
Any help would be appreciated.
Cyber66
Re: Remove Portal Images?
Post by Cyber66 »
I have the exact same question, did you figure it out?
What did you change? Did you use this setting in _block_config.html?:
Cyber66
Post by Cyber66 »
Yes, disabling the icons in block config gives this exact issue: http://portal.novacrew.eu
Cyber66 wrote:Yes, disabling the icons in block config gives this exact issue: http://portal.novacrew.eu
View it here: viewtopic.php?f=36&t=5214&p=29655&hilit ... ime#p29663
Cyber66
Post by Cyber66 »
Thank you, got it fixed now! ;)
For my theme, i had to edit _block_config.html line 2 so it looks like this:
<!-- DEFINE $LR_BLOCK_H_L = '<div class="forabg"><div class="inner"><span class="corners-top"><span></span></span><ul class="topiclist"><li class="header"><dl><dt style="padding: 2px 0px 4px; white-space: nowrap; margin-bottom: 0px; margin-top: 0px;">' -->
Return to “Styles Support”
