Style request "Madevo" [prosilver base]
Styles Anpassungen / Aufträge bitte hier veröffentlichen.
Styles adjustments / requests, please post here.
bipbip-admin
phpBB.de User: bipbip-admin
phpBB.com User: bipbip-admin
Post by bipbip-admin »
Good morning,
i'm sorry, my english is poor but i need your help to modify the board portal 3 v1.0.2 style....my style is MADEVO you can download it on http://www.phpbb3styles.net/db/style/madevo?lang=fr
I'm not an expert in phpbb so thats why i need your help... :oops:
my forum adress is http://www.bipbip-detection.fr/index.ph ... ac33909c4f
Actually i have a temporary style for chrismas....I hope that you can help me.
Thanks very much my friend
Re: Style request "Madevo" [prosilver base]
bipbip-admin wrote:Good morning,
Your board should phpBB v.3.0.9 and B3P v.1.6 have.
Then I can try to write a guide for the style.
anywhere91
Translator
phpBB.com User: Anywhere91
Post by anywhere91 »
Question already asked and answers given early and in French => http://forums.phpbb-fr.com/mods-de-la-b ... 88133.html
Style based on prosilver Madevo with heritage. Make the changes requested in install.xml and :
  • uppload file root/styles/prosilver/*.* in ftp/forum/styles/madevo/*.*
  • Make changes to the files styles/madevo/template/overall_header.html, styles/madevo/template/overall_footer.html, and styles/madevo/theme/stylesheet.css
  • Refresh the style and clear the cache
  • enjoy
Regards
In French
Bonjour / Soir
Question déjà posée et début de réponse apporté et dans le forum phpbb-fr
Style Madevo basé sur prosilver avec heritage. Faire les modifications demandé dans install.xml, puis :
  • Envoyer tout le dossier root/styles/prosilver/*.* dans ftp/forum/styles/madevo/*.*
  • Faire les modifications sur les fichiers styles/madevo/template/overall_header.html, styles/madevo/template/overall_footer.html, et styles/madevo/theme/stylesheet.css
  • Raffraichir le styles et vider le cache
  • En profiter
Cordialement
bipbip-admin
archivar wrote:Your board should phpBB v.3.0.9 and B3P v.1.6 have.
Hi archivar, thanks for answering !
thats right, my board use phpBB 3.0.9 and i have b3p 1.0.6 in french, thanks for help..
Have a good day..
Bonjour anywhere,
merci pour ta réponse, je vais plancher dessus ce week end !
bye
anywhere91
Translator
Modifications to do and test
Prosilver style with héritage (prosilver MUST be in the directory styles/)
Download and install madevo => (latest version http://www.phpbb3styles.net/db/style/madevo )
Open styles/madevo/template/overhall_header.html
<div class="navbar">
<!-- IF not $S_IN_PORTAL or S_DISPLAY_PHPBB_MENU -->
<li class="icon-home"><a href="{U_INDEX}" accesskey="h">{L_INDEX}</a> <!-- BEGIN navlinks --> <strong>&#8249;</strong>
<!-- IF U_PORTAL --><a href="{U_PORTAL}">{L_PORTAL}</a> &#187; <!-- ENDIF -->
        <div id="page-body">
            <!-- IF S_BOARD_DISABLED and S_USER_LOGGED_IN and (U_MCP or U_ACP) -->
            <div id="information" class="rules">
                <div class="inner">
                    <strong>{L_INFORMATION}:</strong> {L_BOARD_DISABLED}
            <!-- ENDIF -->
<!-- ENDIF -->
Openstyles/madevo/template/overhall_footer.html
Open styles/madevo/theme/stylesheet.css
@import url("madevo.css");
@import url("portal.css");
Refresh template, theme, imageset and purge cache
Enjoy
In french
Bonjour / Soir
Pour faire suite a ce message, voici les modifications à faire
Style avec héritage prosilver (prosilver DOIT être dans le répertoire styles/)
Télécharger et installez madevo => (dernière version http://www.phpbb3styles.net/db/style/madevo )
Ouvrir styles/madevo/template/overhall_header.html
Rechercher
Ajouter avant
Rechercher
Rechercher dans
Ajouter après
Rechercher
                <div class="inner">
            <!-- ENDIF -->
Ajouter avant
<!-- ENDIF -->
Ouvrir styles/madevo/template/overhall_footer.html
Rechercher
Rechercher dans
Ajouter après
Ouvrir styles/madevo/theme/stylesheet.css
Rechercher
Ajouter après
Rafraichir template, theme, imaset et vider le cache
cordialement
Return to “Style requests”
