Can I update 2.0.0b1 -> 2.0.1 directly ?
Current Version: 2.0.2
Released: 2013-10-27
robra
phpBB.de User: robra
phpBB.com User: robra
Post by robra »
Your Portal Version: 2.0.0b1
Boardlink: http://chakra-linux.com.br/forum/
Is not problem. Is only one doubt.
I would like to know if I can update the 2.0.0b1 version directly to the 2.0.1 version or I need update to the 2.0.0 version first.
Because the 2.0.1 /contrib folder only treats about 2.0.0 -> 2.0.1.
Thanks. Image
Re: Can I update 2.0.0b1 -> 2.0.1 directly ?
Updates from earlier versions than 2.0.0 were dropped in Board3 Portal 2.0.1. You'll have to update from 2.0.0b1 to 2.0.0 and then to 2.0.1.
robra
Post by robra »
Okay.
Thank you for the quick answer. Image
