ajak shoutbox by handyman on portal
killians1978
Re: ajak shoutbox by handyman on portal
Post by killians1978 »
Wow, server must've had a hiccup and put my reply before your post. :D
Anyway, yeah, it's exactly the same, but in a different spot. Almost as if chat_body.html itself doesn't agree with where it is. Take a look and you'll see what I mean. Works just fine on the board index, but not on the portal page.
killians1978 wrote:Wow, server must've had a hiccup and put my reply before your post. :D
That is really weird! :shock:
ather
phpBB.com User: ather90
Post by ather »
hmm, werid, very weird..try to place the
<!-- INCLUDE chat_body.html -->
in the overall_header file :)
novanilla
Post by novanilla »
Handyman's Chatbox needs the same modifications performed to the portal.php file as he has listed in the index.php file, if I recall correctly. He has the code add-ins documented in index.php so they're easy to find. I have it implemented on my site, and it works great, once you put the "include" line in your portal_body.html file.
If you need help with it, I'll check in later and see what I can do. I have a screen capture I can show you later too, if needed.
