Fehler bei Installation von Version 1.0.3
Patrick68
Re: Fehler bei Installation von Version 1.0.3
Post by Patrick68 »
die seite bleibt weiß naja...
kann man das jetzt alles irgendwie wiederholen...also das aufrufen der install?? Hab jetzt nochmals alle änderungen gecheckt und keinen fehler gefunden...
oder würde es was bringen deinstallation und neu??nein hab ich gemacht
als anhang mal die adm/index.php
* @package acp
* @version $Id: index.php 8591 2008-06-04 11:40:53Z Kellanved $
define('IN_PHPBB', true);
define('ADMIN_START', true);
define('NEED_SID', true);
// Include files
$phpbb_root_path = (defined('PHPBB_ROOT_PATH')) ? PHPBB_ROOT_PATH : './../';
require($phpbb_root_path . 'common.' . $phpEx);
require($phpbb_root_path . 'includes/functions_admin.' . $phpEx);
require($phpbb_root_path . 'includes/functions_module.' . $phpEx);
require($phpbb_root_path . 'portal/includes/lang_adm_additional_blocks.' . $phpEx);
// Start session management
$user->session_begin();
$auth->acl($user->data);
$user->setup('acp/common');
// End session management
require($phpbb_root_path . 'includes/functions_module.' . $phpEx);// Have they authenticated (again) as an admin for this session?
if (!isset($user->data['session_admin']) || !$user->data['session_admin'])
	login_box('', $user->lang['LOGIN_ADMIN_CONFIRM'], $user->lang['LOGIN_ADMIN_SUCCESS'], true, false);
// Is user any type of admin? No, then stop here, each script needs to
// check specific permissions but this is a catchall
if (!$auth->acl_get('a_'))
	trigger_error('NO_ADMIN');
// We define the admin variables now, because the user is now able to use the admin related features...
define('IN_ADMIN', true);
$phpbb_admin_path = (defined('PHPBB_ADMIN_PATH')) ? PHPBB_ADMIN_PATH : './';
// Some oft used variables
$safe_mode		= (@ini_get('safe_mode') == '1' || strtolower(@ini_get('safe_mode')) === 'on') ? true : false;
$file_uploads	= (@ini_get('file_uploads') == '1' || strtolower(@ini_get('file_uploads')) === 'on') ? true : false;
$module_id		= request_var('i', '');
$mode			= request_var('mode', '');
// Set custom template for admin area
$template->set_custom_template($phpbb_admin_path . 'style', 'admin');
$template->assign_var('T_TEMPLATE_PATH', $phpbb_admin_path . 'style');
// the acp template is never stored in the database
$user->theme['template_storedb'] = false;
// Instantiate new module
$module = new p_master();
// Instantiate module system and generate list of available modules
$module->list_modules('acp');
// Select the active module
$module->set_active($module_id, $mode);
// Assign data to the template engine for the list of modules
// We do this before loading the active module for correct menu display in trigger_error
$module->assign_tpl_vars(append_sid("{$phpbb_admin_path}index.$phpEx"));
// Load and execute the relevant module
$module->load_active();
// Generate the page
adm_page_header($module->get_page_title());
	'body' => $module->get_tpl_name(),
adm_page_footer();
* Header for acp pages
function adm_page_header($page_title)
	global $config, $db, $user, $template;
	global $phpbb_root_path, $phpbb_admin_path, $phpEx, $SID, $_SID;
	if (defined('HEADER_INC'))
		return;
	define('HEADER_INC', true);
	// gzip_compression
	if ($config['gzip_compress'])
		if (@extension_loaded('zlib') && !headers_sent())
			ob_start('ob_gzhandler');
	$template->assign_vars(array(
		'PAGE_TITLE'			=> $page_title,
		'USERNAME'				=> $user->data['username'],
		'SID'					=> $SID,
		'_SID'					=> $_SID,
		'SESSION_ID'			=> $user->session_id,
		'ROOT_PATH'				=> $phpbb_admin_path,
		'U_LOGOUT'				=> append_sid("{$phpbb_root_path}ucp.$phpEx", 'mode=logout'),
		'U_ADM_LOGOUT'			=> append_sid("{$phpbb_admin_path}index.$phpEx", 'action=admlogout'),
		'U_ADM_INDEX'			=> append_sid("{$phpbb_admin_path}index.$phpEx"),
		'U_INDEX'				=> append_sid("{$phpbb_root_path}index.$phpEx"),
		'T_IMAGES_PATH'			=> "{$phpbb_root_path}images/",
		'T_SMILIES_PATH'		=> "{$phpbb_root_path}{$config['smilies_path']}/",
		'T_AVATAR_PATH'			=> "{$phpbb_root_path}{$config['avatar_path']}/",
		'T_AVATAR_GALLERY_PATH'	=> "{$phpbb_root_path}{$config['avatar_gallery_path']}/",
		'T_ICONS_PATH'			=> "{$phpbb_root_path}{$config['icons_path']}/",
		'T_RANKS_PATH'			=> "{$phpbb_root_path}{$config['ranks_path']}/",
		'T_UPLOAD_PATH'			=> "{$phpbb_root_path}{$config['upload_path']}/",
		'ICON_MOVE_UP'				=> '<img src="' . $phpbb_admin_path . 'images/icon_up.gif" alt="' . $user->lang['MOVE_UP'] . '" title="' . $user->lang['MOVE_UP'] . '" />',
		'ICON_MOVE_UP_DISABLED'		=> '<img src="' . $phpbb_admin_path . 'images/icon_up_disabled.gif" alt="' . $user->lang['MOVE_UP'] . '" title="' . $user->lang['MOVE_UP'] . '" />',
		'ICON_MOVE_DOWN'			=> '<img src="' . $phpbb_admin_path . 'images/icon_down.gif" alt="' . $user->lang['MOVE_DOWN'] . '" title="' . $user->lang['MOVE_DOWN'] . '" />',
		'ICON_MOVE_DOWN_DISABLED'	=> '<img src="' . $phpbb_admin_path . 'images/icon_down_disabled.gif" alt="' . $user->lang['MOVE_DOWN'] . '" title="' . $user->lang['MOVE_DOWN'] . '" />',
		'ICON_EDIT'					=> '<img src="' . $phpbb_admin_path . 'images/icon_edit.gif" alt="' . $user->lang['EDIT'] . '" title="' . $user->lang['EDIT'] . '" />',
		'ICON_EDIT_DISABLED'		=> '<img src="' . $phpbb_admin_path . 'images/icon_edit_disabled.gif" alt="' . $user->lang['EDIT'] . '" title="' . $user->lang['EDIT'] . '" />',
		'ICON_DELETE'				=> '<img src="' . $phpbb_admin_path . 'images/icon_delete.gif" alt="' . $user->lang['DELETE'] . '" title="' . $user->lang['DELETE'] . '" />',
		'ICON_DELETE_DISABLED'		=> '<img src="' . $phpbb_admin_path . 'images/icon_delete_disabled.gif" alt="' . $user->lang['DELETE'] . '" title="' . $user->lang['DELETE'] . '" />',
		'ICON_SYNC'					=> '<img src="' . $phpbb_admin_path . 'images/icon_sync.gif" alt="' . $user->lang['RESYNC'] . '" title="' . $user->lang['RESYNC'] . '" />',
		'ICON_SYNC_DISABLED'		=> '<img src="' . $phpbb_admin_path . 'images/icon_sync_disabled.gif" alt="' . $user->lang['RESYNC'] . '" title="' . $user->lang['RESYNC'] . '" />',
		'S_USER_LANG'			=> $user->lang['USER_LANG'],
		'S_CONTENT_DIRECTION'	=> $user->lang['DIRECTION'],
		'S_CONTENT_ENCODING'	=> 'UTF-8',
		'S_CONTENT_FLOW_BEGIN'	=> ($user->lang['DIRECTION'] == 'ltr') ? 'left' : 'right',
		'S_CONTENT_FLOW_END'	=> ($user->lang['DIRECTION'] == 'ltr') ? 'right' : 'left',
	// application/xhtml+xml not used because of IE
	header('Content-type: text/html; charset=UTF-8');
	header('Cache-Control: private, no-cache="set-cookie"');
	header('Expires: 0');
	header('Pragma: no-cache');
	return;
* Page footer for acp pages
function adm_page_footer($copyright_html = true)
	global $db, $config, $template, $user, $auth, $cache;
	global $starttime, $phpbb_root_path, $phpbb_admin_path, $phpEx;
	// Output page creation time
	if (defined('DEBUG'))
		$mtime = explode(' ', microtime());
		$totaltime = $mtime[0] + $mtime[1] - $starttime;
		if (!empty($_REQUEST['explain']) && $auth->acl_get('a_') && defined('DEBUG_EXTRA') && method_exists($db, 'sql_report'))
			$db->sql_report('display');
		$debug_output = sprintf('Time : %.3fs | ' . $db->sql_num_queries() . ' Queries | GZIP : ' . (($config['gzip_compress']) ? 'On' : 'Off') . (($user->load) ? ' | Load : ' . $user->load : ''), $totaltime);
		if ($auth->acl_get('a_') && defined('DEBUG_EXTRA'))
			if (function_exists('memory_get_usage'))
				if ($memory_usage = memory_get_usage())
					global $base_memory_usage;
					$memory_usage -= $base_memory_usage;
					$memory_usage = get_formatted_filesize($memory_usage);
					$debug_output .= ' | Memory Usage: ' . $memory_usage;
			$debug_output .= ' | <a href="' . build_url() . '&explain=1">Explain</a>';
		'DEBUG_OUTPUT'		=> (defined('DEBUG')) ? $debug_output : '',
		'TRANSLATION_INFO'	=> (!empty($user->lang['TRANSLATION_INFO'])) ? $user->lang['TRANSLATION_INFO'] : '',
		'S_COPYRIGHT_HTML'	=> $copyright_html,
		'VERSION'			=> $config['version'])
	$template->display('body');
	garbage_collection();
	exit_handler();
* Generate back link for acp pages
function adm_back_link($u_action)
	global $user;
	return '<br /><br /><a href="' . $u_action . '">&laquo; ' . $user->lang['BACK_TO_PREV'] . '</a>';
* Build select field options in acp pages
function build_select($option_ary, $option_default = false)
	global $user;
	$html = '';
	foreach ($option_ary as $value => $title)
		$selected = ($option_default !== false && $value == $option_default) ? ' selected="selected"' : '';
		$html .= '<option value="' . $value . '"' . $selected . '>' . $user->lang[$title] . '</option>';
	return $html;
* Build radio fields in acp pages
function h_radio($name, &$input_ary, $input_default = false, $id = false, $key = false)
	global $user;
	$html = '';
	$id_assigned = false;
	foreach ($input_ary as $value => $title)
		$selected = ($input_default !== false && $value == $input_default) ? ' checked="checked"' : '';
		$html .= '<label><input type="radio" name="' . $name . '"' . (($id && !$id_assigned) ? ' id="' . $id . '"' : '') . ' value="' . $value . '"' . $selected . (($key) ? ' accesskey="' . $key . '"' : '') . ' class="radio" /> ' . $user->lang[$title] . '</label>';
		$id_assigned = true;
	return $html;
* Build configuration template for acp configuration pages
function build_cfg_template($tpl_type, $key, &$new, $config_key, $vars)
	global $user, $module;
	$tpl = '';
	$name = 'config[' . $config_key . ']';
	switch ($tpl_type[0])
		case 'text':
		case 'password':
			$size = (int) $tpl_type[1];
			$maxlength = (int) $tpl_type[2];
			$tpl = '<input id="' . $key . '" type="' . $tpl_type[0] . '"' . (($size) ? ' size="' . $size . '"' : '') . ' maxlength="' . (($maxlength) ? $maxlength : 255) . '" name="' . $name . '" value="' . $new[$config_key] . '" />';
		break;
		case 'dimension':
			$tpl = '<input id="' . $key . '" type="text"' . (($size) ? ' size="' . $size . '"' : '') . ' maxlength="' . (($maxlength) ? $maxlength : 255) . '" name="config[' . $config_key . '_width]" value="' . $new[$config_key . '_width'] . '" /> x <input type="text"' . (($size) ? ' size="' . $size . '"' : '') . ' maxlength="' . (($maxlength) ? $maxlength : 255) . '" name="config[' . $config_key . '_height]" value="' . $new[$config_key . '_height'] . '" />';
		break;
		case 'textarea':
			$rows = (int) $tpl_type[1];
			$cols = (int) $tpl_type[2];
			$tpl = '<textarea id="' . $key . '" name="' . $name . '" rows="' . $rows . '" cols="' . $cols . '">' . $new[$config_key] . '</textarea>';
		break;
		case 'radio':
			$key_yes	= ($new[$config_key]) ? ' checked="checked"' : '';
			$key_no		= (!$new[$config_key]) ? ' checked="checked"' : '';
			$tpl_type_cond = explode('_', $tpl_type[1]);
			$type_no = ($tpl_type_cond[0] == 'disabled' || $tpl_type_cond[0] == 'enabled') ? false : true;
			$tpl_no = '<label><input type="radio" name="' . $name . '" value="0"' . $key_no . ' class="radio" /> ' . (($type_no) ? $user->lang['NO'] : $user->lang['DISABLED']) . '</label>';
			$tpl_yes = '<label><input type="radio" id="' . $key . '" name="' . $name . '" value="1"' . $key_yes . ' class="radio" /> ' . (($type_no) ? $user->lang['YES'] : $user->lang['ENABLED']) . '</label>';
			$tpl = ($tpl_type_cond[0] == 'yes' || $tpl_type_cond[0] == 'enabled') ? $tpl_yes . $tpl_no : $tpl_no . $tpl_yes;
		break;
		case 'select':
		case 'custom':
			$return = '';
			if (isset($vars['method']))
				$call = array($module->module, $vars['method']);
			else if (isset($vars['function']))
				$call = $vars['function'];
				break;
			if (isset($vars['params']))
				$args = array();
				foreach ($vars['params'] as $value)
					switch ($value)
						case '{CONFIG_VALUE}':
							$value = $new[$config_key];
						break;
						case '{KEY}':
							$value = $key;
						break;
					$args[] = $value;
				$args = array($new[$config_key], $key);
			$return = call_user_func_array($call, $args);
			if ($tpl_type[0] == 'select')
				$tpl = '<select id="' . $key . '" name="' . $name . '">' . $return . '</select>';
				$tpl = $return;
		break;
		default:
		break;
	if (isset($vars['append']))
		$tpl .= $vars['append'];
	return $tpl;
* Going through a config array and validate values, writing errors to $error. The validation method  accepts parameters separated by ':' for string and int.
* The first parameter defines the type to be used, the second the lower bound and the third the upper bound. Only the type is required.
function validate_config_vars($config_vars, &$cfg_array, &$error)
	global $phpbb_root_path, $user;
	$type	= 0;
	$min	= 1;
	$max	= 2;
	foreach ($config_vars as $config_name => $config_definition)
		if (!isset($cfg_array[$config_name]) || strpos($config_name, 'legend') !== false)
			continue;
		if (!isset($config_definition['validate']))
			continue;
		$validator = explode(':', $config_definition['validate']);
		// Validate a bit. ;) (0 = type, 1 = min, 2= max)
		switch ($validator[$type])
			case 'string':
				$length = strlen($cfg_array[$config_name]);
				// the column is a VARCHAR
				$validator[$max] = (isset($validator[$max])) ? min(255, $validator[$max]) : 255;
				if (isset($validator[$min]) && $length < $validator[$min])
					$error[] = sprintf($user->lang['SETTING_TOO_SHORT'], $user->lang[$config_definition['lang']], $validator[$min]);
				else if (isset($validator[$max]) && $length > $validator[2])
					$error[] = sprintf($user->lang['SETTING_TOO_LONG'], $user->lang[$config_definition['lang']], $validator[$max]);
			break;
			case 'bool':
				$cfg_array[$config_name] = ($cfg_array[$config_name]) ? 1 : 0;
			break;
			case 'int':
				$cfg_array[$config_name] = (int) $cfg_array[$config_name];
				if (isset($validator[$min]) && $cfg_array[$config_name] < $validator[$min])
					$error[] = sprintf($user->lang['SETTING_TOO_LOW'], $user->lang[$config_definition['lang']], $validator[$min]);
				else if (isset($validator[$max]) && $cfg_array[$config_name] > $validator[$max])
					$error[] = sprintf($user->lang['SETTING_TOO_BIG'], $user->lang[$config_definition['lang']], $validator[$max]);
			break;
			// Absolute path
			case 'script_path':
				if (!$cfg_array[$config_name])
					break;
				$destination = str_replace('\\', '/', $cfg_array[$config_name]);
				if ($destination !== '/')
					// Adjust destination path (no trailing slash)
					if (substr($destination, -1, 1) == '/')
						$destination = substr($destination, 0, -1);
					$destination = str_replace(array('../', './'), '', $destination);
					if ($destination[0] != '/')
						$destination = '/' . $destination;
				$cfg_array[$config_name] = trim($destination);
			break;
			// Absolute path
			case 'lang':
					break;
				$cfg_array[$config_name] = basename($cfg_array[$config_name]);
				if (!file_exists($phpbb_root_path . 'language/' . $cfg_array[$config_name] . '/'))
					$error[] = $user->lang['WRONG_DATA_LANG'];
			break;
			// Relative path (appended $phpbb_root_path)
			case 'rpath':
			case 'rwpath':
					break;
				$destination = $cfg_array[$config_name];
				if (substr($destination, -1, 1) == '/' || substr($destination, -1, 1) == '\\')
				$destination = str_replace(array('../', '..\\', './', '.\\'), '', $destination);
				if ($destination && ($destination[0] == '/' || $destination[0] == "\\"))
					$destination = '';
			// Path being relative (still prefixed by phpbb_root_path), but with the ability to escape the root dir...
			case 'path':
			case 'wpath':
					break;
				$cfg_array[$config_name] = trim($cfg_array[$config_name]);
				// Make sure no NUL byte is present...
				if (strpos($cfg_array[$config_name], "\0") !== false || strpos($cfg_array[$config_name], '%00') !== false)
					$cfg_array[$config_name] = '';
					break;
				if (!file_exists($phpbb_root_path . $cfg_array[$config_name]))
					$error[] = sprintf($user->lang['DIRECTORY_DOES_NOT_EXIST'], $cfg_array[$config_name]);
				if (file_exists($phpbb_root_path . $cfg_array[$config_name]) && !is_dir($phpbb_root_path . $cfg_array[$config_name]))
					$error[] = sprintf($user->lang['DIRECTORY_NOT_DIR'], $cfg_array[$config_name]);
				// Check if the path is writable
				if ($config_definition['validate'] == 'wpath' || $config_definition['validate'] == 'rwpath')
					if (file_exists($phpbb_root_path . $cfg_array[$config_name]) && !@is_writable($phpbb_root_path . $cfg_array[$config_name]))
						$error[] = sprintf($user->lang['DIRECTORY_NOT_WRITABLE'], $cfg_array[$config_name]);
			break;
	return;
* Checks whatever or not a variable is OK for use in the Database
* param mixed $value_ary An array of the form array(array('lang' => ..., 'value' => ..., 'column_type' =>))'
* param mixed $error The error array
function validate_range($value_ary, &$error)
	global $user;
	$column_types = array(
		'BOOL'	=> array('php_type' => 'int', 		'min' => 0, 				'max' => 1),
		'USINT'	=> array('php_type' => 'int',		'min' => 0, 				'max' => 65535),
		'UINT'	=> array('php_type' => 'int', 		'min' => 0, 				'max' => (int) 0x7fffffff),
		'INT'	=> array('php_type' => 'int', 		'min' => (int) 0x80000000, 	'max' => (int) 0x7fffffff),
		'TINT'	=> array('php_type' => 'int',		'min' => -128,				'max' => 127),
		'VCHAR'	=> array('php_type' => 'string', 	'min' => 0, 				'max' => 255),
	foreach ($value_ary as $value)
		$column = explode(':', $value['column_type']);
		$max = $min = 0;
		$type = 0;
		if (!isset($column_types[$column[0]]))
			continue;
			$type = $column_types[$column[0]];
		switch ($type['php_type'])
			case 'string' :
				$max = (isset($column[1])) ? min($column[1],$type['max']) : $type['max'];
				if (strlen($value['value']) > $max)
					$error[] = sprintf($user->lang['SETTING_TOO_LONG'], $user->lang[$value['lang']], $max);
			break;
			case 'int':
				$min = (isset($column[1])) ? max($column[1],$type['min']) : $type['min'];
				$max = (isset($column[2])) ? min($column[2],$type['max']) : $type['max'];
				if ($value['value'] < $min)
					$error[] = sprintf($user->lang['SETTING_TOO_LOW'], $user->lang[$value['lang']], $min);
				else if ($value['value'] > $max)
					$error[] = sprintf($user->lang['SETTING_TOO_BIG'], $user->lang[$value['lang']], $max);
			break;
Mit dem Installer, bzw einer Deinstallation darüber wirst du nichts werden.
Die weiße Seite kommt 100% aus einer fehlerhaften Editierung deinerseits.
Check den KB Artikel und deine Änderungen daraufhin noch mal genau durch.
Patrick68
Post by Patrick68 »
hab ich ja ..es kann ja eignetlich nur die adm/index.php betreffen
auf der Portalseite fehlen mir auch die links zu den faqs und der Mitgliederliste...kann natürlich sein weil ich ja nix aktualisieren kann komme ja nich in adminbereich....
Nimm mal eine originale adm/index.php aus dem aktuellen phpBB3 Paket und mache die Änderungen dort noch mal neu:
portal_docs/install.xml#adm/index.php
Patrick68
Post by Patrick68 »
es geht jipiiiihhhhh ich küsse dich aber in einem anderen leben lol jetzt kann ich weiterarbeiten danke!!!!!!
Morpheus
Post by Morpheus »
Christian_N wrote:Nichts sehr witzig dann hast die Update-Anleitung nicht richtig bearbeitet besonders die Datei adm/index.php ;)
Den dort steht das die Zeile löschen sollst - siehe hier: portal_docs/contrib/update_board3portal ... /index.php ;)
Finde und ersetze mit (ne leere Zeile) - steht dort, wenn das machst kommt auch der Fehler nicht, geh die Update-Anleitung richtig durch und es stimmt alles. :)
NACHTRAG: Da war Kevin schneller :lol:
Danke ;)
Hatte das gleiche Problem wie Patrick, lang_portal_acp_logs.php couldn't be opened.
Wer lesen kann ist klar im Vorteil :)
morph
//Edit: Dürfte daran gelegen haben das ich nicht die update_board_102.xml sonder die install.xml durchgegangen bin, in der diese Passage nicht enthalten ist.
