I've installed Board3 and its awesome
Its a stupid question but can I add my own HTML and PHP to the Welcome Box?
Which file do I need to edit to go about this. Can it only be done purely through the ACP?
Thanks in advance.
php on welcome Block
Re: Portal
If you want to add your own html, you could edit the welcome.html in your styles/prosilver/template/portal/block/ folder.
But you could also use BBCode, since it basically does the same as html code.
- phpBB.de User: webslug
- phpBB.com User: webslug
Re: Portal
Ok thanks, expanding on this.
I've added the following line to the .htaccess file to allow PHP in HTML files in the root folder.
AddType application/x-httpd-php .html .htm
However it doesn't seem to be working when I use the <? echo ("hello"); ?> statement in the welcome.html file.
Do I need to create a .htaccess within the template/portal/block/ to allow PHP to be used in this file.
Re: Portal
You dont need any changes of your htaccess files. Just allow php in templates via ACP ![Zwinkern ;)](./images/smilies/icon_e_wink.gif)
Server Config -> Security -> allow php in Templates...
I dont know the exactly wording in english cause i use another language pack![Zwinkern ;)](./images/smilies/icon_e_wink.gif)
Re: Portal
Thanks it worked great although I had to enclose the PHP statements in the following. I thought I'd post it here to save somebody else some time.
<!-- PHP -->
echo ("test");
<!-- ENDPHP -->
