Boardlink: [url]http://localhost_only[/url]
MySQL Version: 5.1.48-community
Installed Topic Preview for Board3.
Tried installation on fresh copy (no uninstall) of program and database, twice with same results.
In effect, if I disable Topic Preview in UCP > board prefs > edit display options, I get no SQL error and Recent Topics works ok.
Do not know what to do. Noob here. Please bear with me.
SQL ERROR [ mysqli ]
Column 'forum_id' in where clause is ambiguous [1052]
SQL
SELECT t.topic_title, t.forum_id, t.topic_id , pt.post_text AS topic_preview_text FROM phpbb_topics t LEFT JOIN phpbb_posts pt ON (pt.post_id = t.topic_first_post_id)WHERE t.topic_status <> 2 AND t.topic_approved = 1 AND (t.topic_type = 2 OR t.topic_type = 3) AND t.topic_moved_id = 0 AND forum_id IN ('4', '14', '15', '16', '5', '6') ORDER BY t.topic_time DESC LIMIT 5
BACKTRACE
FILE: includes/db/mysqli.php
LINE: 163
CALL: dbal->sql_error()
LINE: 205
FILE: includes/db/dbal.php
LINE: 170
FILE: portal/block/recent.php
LINE: 77
CALL: dbal->sql_query_limit()
FILE: index.php
LINE: 99
CALL: include('portal/block/recent.php')
Topic Preview for Board3 : SQL conflict with "Recent Topics"
Re: Topic Preview for Board3 : SQL conflict with "Recent Top
What version of Board3 Portal are you using? It seems to me like your recent.php is outdated.
I have version 1.0.5.
The Check Version says it is updated.
Thanks Mark.
Thanks Mark.
Replace the recent.php with the one from the current Board3 Portal package and redo the changes.
It looks like the incompatibilities are with "Topic Preview MOD" code.
Here is recent.php file with the blocks of code pertaining to Topic Preview MOD separated with dotted lines (................)
With the other Board3 blocks, Topic Preview MOD works ok.
* @package - Board3portal
* @version $Id: recent.php 589 2009-12-04 21:11:16Z marc1706 $
exit;
// Exclude forums
$sql_where = '';
if ($portal_config['portal_recent_forum'] > 0)
$exclude_forums = explode(',', $portal_config['portal_recent_forum']);
$sql_where = ' AND ' . $db->sql_in_set('forum_id', $exclude_forums, ($portal_config['portal_exclude_forums']) ? true : false);
// Get a list of forums the user cannot read
$forum_ary = array_unique(array_keys($auth->acl_getf('!f_read', true)));
// Determine first forum the user is able to read (must not be a category)
$sql = 'SELECT forum_id
FROM ' . FORUMS_TABLE . '
WHERE forum_type = ' . FORUM_POST;
$forum_sql = '';
if (sizeof($forum_ary))
$sql .= ' AND ' . $db->sql_in_set('forum_id', $forum_ary, true);
$forum_sql = ' AND ' . $db->sql_in_set('t.forum_id', $forum_ary, true);
$g_forum_id = (int) $db->sql_fetchfield('forum_id');
// Recent announcements
// BEGIN Topic Preview Mod
if ($config['topic_preview_limit'] && $user->data['user_topic_preview'])
$sql_join = ' LEFT JOIN ' . POSTS_TABLE . ' pt ON (pt.post_id = t.topic_first_post_id)';
$sql_select = ', pt.post_text AS topic_preview_text';
$sql = 'SELECT t.topic_title, t.forum_id, t.topic_id ' . $sql_select . '
FROM ' . TOPICS_TABLE . ' t
' . $sql_join . 'WHERE t.topic_status <> ' . FORUM_LINK . '
AND (t.topic_type = ' . POST_ANNOUNCE . ' OR t.topic_type = ' . POST_GLOBAL . ')
' . $sql_where . '' . $forum_sql . '
ORDER BY t.topic_time DESC';
$sql = 'SELECT topic_title, forum_id, topic_id
WHERE topic_status <> ' . FORUM_LINK . '
AND topic_approved = 1
AND (topic_type = ' . POST_ANNOUNCE . ' OR topic_type = ' . POST_GLOBAL . ')
AND topic_moved_id = 0
ORDER BY topic_time DESC';
// END Topic Preview Mod
$result = $db->sql_query_limit($sql, $portal_config['portal_max_topics']);
while(($row = $db->sql_fetchrow($result)) && ($row['topic_title']))
// auto auth
if (($auth->acl_get('f_read', $row['forum_id'])) || ($row['forum_id'] == '0'))
$template->assign_block_vars('latest_announcements', array(
'TOPIC_PREVIEW_TEXT' => (!empty($row['topic_preview_text'])) ? censor_text(trim_topic_preview($row['topic_preview_text'], $config['topic_preview_limit'])) : character_limit($row['topic_title'], $portal_config['portal_recent_title_limit']),
'TITLE' => character_limit($row['topic_title'], $portal_config['portal_recent_title_limit']),
'FULL_TITLE' => censor_text($row['topic_title']),
'U_VIEW_TOPIC' => append_sid("{$phpbb_root_path}viewtopic.$phpEx", 'f=' . (($row['forum_id'] == 0) ? $g_forum_id : $row['forum_id']) . '&t=' . $row['topic_id'])
$db->sql_freeresult($result);
// Recent hot topics
' . $sql_join . 'WHERE t.topic_approved = 1
AND t.topic_replies >=' . $config['hot_threshold'] . '
WHERE topic_approved = 1
AND topic_replies >=' . $config['hot_threshold'] . '
// auto auth
$template->assign_block_vars('latest_hot_topics', array(
// Recent topic (only show normal topic)
' . $sql_join . 'WHERE t.topic_status <> ' . ITEM_MOVED . '
AND t.topic_type = ' . POST_NORMAL . '
WHERE topic_status <> ' . ITEM_MOVED . '
AND topic_type = ' . POST_NORMAL . '
// auto auth
$template->assign_block_vars('latest_topics', array(
'U_VIEW_TOPIC' => append_sid("{$phpbb_root_path}viewtopic.$phpEx", 'f=' . $row['forum_id'] . '&t=' . $row['topic_id'])
$template->assign_var('S_DISPLAY_RECENT', true);
Ok, find every sql query that looks like this:
And add a t. in front of everything, i.e.:
Then it should work.
ORDER BY topic_time DESC';Code: Select all
ORDER BY t.topic_time DESC';Re: Topic Preview for Board3 : SQL conflict with "Recent Top
OK, you fixed it.
but I had to ad a "t." also on line 26 to the "forum_id" variable like
I have tested the queries without the t. and it works ok just the same.
So it looks like this is the only correction needed.
I left the queries as you suggested anyway.
Thank you.
$sql_where = ' AND ' . $db->sql_in_set('t.forum_id', $exclude_forums, ($portal_config['portal_exclude_forums']) ? true : false);
Thank you.
