1.0.6 Installed but it says 1.0.5 is the current version
Genopath
Post by Genopath »
Boardlink: http://finalascension.org
I did refresh and purged the cache as well. Is this a known bug?
Re: 1.0.6 Installed but it says 1.0.5 is the current version
Not as far as I know, it works over here. Did you try to purge your board cache?
Genopath
Post by Genopath »
Yea I did. Reinstalled a few times and still it says 1.0.5
Also I discovered recently that the attachments title block says
" { ATTACHMENTS2 }"
Instead of Attachments. How do I fix that as well?
Your styles/starcraft/template/portal/block/attachments.html is not the one from the portal package. It seems like it is edited and that causes the error you mentioned in the attachments block. Did you run the installer after uploading the new Portal files?
Genopath
Post by Genopath »
reinstall did the trick and fixed it.
However in the portal I remember I had the attachements block say "Downloads". Where do I modify this again? I just checked lang_portal and it wasn't there.
language/*yourlanguage/mods/lang_portal.php
Genopath
Post by Genopath »
Yea I checked there and no luck.
Then I know why you had {L_ATTACHMENTS2} in your block file.
Add the language variable 'ATTACHMENTS2' to your language file and change {L_ATTACHMENTS} to {L_ATTACHMENTS2} in styles/starcraft/template/portal/block/attachments.html.
