Portal not looking right with prosilver se
Boardlink: http://fnolan.nolansoft.com/form
PHP Version: 3.0.7-PL1
Nothing, was there since installing Board3
Looked through these forums and tried replacing the _block_config.html with the one Mike made but didn't change anything. And I did refresh the cache for the style and forum.
I installed Board3 in to my Prosilver SE style but it doesn't look right.
Here's the sample page from Mikes install . . .
http://fnolan.nolansoft.com/form/images ... portal.gif
Mine looks like this . . .
Any ideas what is wrong ? Did I miss an edit or edited a file wrong ? I've tried to find the problem but can't seem to find it. Any help would be appreciated.
Edit: Images too large.
Greetings archivar
Greetings archivar
Re: Portal not looking right with prosilver se
You must have root / styles / prosilver_se / template / portal / _block_config.html change.
viewtopic.php?f=44&t=2878
Thanks for the quick reply but as stated in my original post I alreday tried that. I replaced the file that came with the download with it.
I see very clearly that has not changed _block_config.html !!!!!!!!!!!!!!
Did you also already did that?
Refresh your Styles:
I copied the code and created a file called _block_config_html and uploaded it to the folder. I don't know what you are looking at to see that it hasn't been changed. I'll try reuploading it and see what happens.archivar wrote:I see very clearly that has not changed _block_config.html !!!!!!!!!!!!!!
Ok, apparently I uploaded it to the wrong portal folder, I put it in the correct one and it does now match the theme. But it isn't sized right, I assume I need to make the center blocks smaller in width.
Remove once the commercial break, which seems not to fit there.
Look here: knowledge/kb_show.php?id=51
Thanks for your help, I'm not sure what you mean by "commercial break", which file am I looking at to remove this commercial break ?
The block under the header: "Advertisement"
Construction times to test the original overall_header.html again and you will see what I mean.
EDIT:
Remove, as a test, this code from the overall_header.html:
For I believe it is the cause.
EDIT:
<!-- IF ADS_2 -->
<div class="forabg">
<div class="inner"><span class="corners-top"></span>
<ul class="topiclist">
<li class="header">
<dl class="icon">
<dt>{L_ADVERTISEMENT}</dt>
</dl>
</li>
<div style="padding: 5px 5px 2px 5px; font-size: 1.1em; background-color: #ECF1F3; margin: 0px auto; text-align: center;">
<br/>{ADS_2}<br/>
<span class="corners-bottom"></span></div>
<!-- ENDIF --> V.G. archivar
Removed said code but it didn't help, here's an image of the site after removing the code . . .
Could it be something in the CSS file ?
Greetings archivar
Greetings archivar
Construction to the original (clean) overall_header.html and the overall_footer.html again. If the error still exists, then your entries in the ACP -> Portal Settings -> "welcome settings", remove, and remove entries in your "custom block settings for the center block".
Sorry for my bad english.
You didn't edit overall_header.html correctly. You were supposed to put an <!-- ENDIF --> after this:
But, you put if after this:
</div>Code: Select all
<li class="icon-logout"><a href="{U_LOGIN_LOGOUT}" title="{L_LOGIN_LOGOUT}" accesskey="x">{L_LOGIN_LOGOUT}</a></li>Re: Portal not looking right with prosilver se
Thanks archiver and Marc. I tried to set my overall_header.html back to a fresh version but apparently used a bad copy. Now my site doesn't even come up.
Shows an error in the file - "Parse error: parse error, unexpected '}' in /var/www/fnolan/form/cache/tpl_prosilver-se_overall_header.html.php on line 160"
Can't get in to refresh the cache so I guess I'm going to have to wait until it times itself out and refreshes on it's own. I'm going away for the weekend so wont have a lot of time to play with it.
EDIT: Thank You Marc, that did the trick ! Looks fine now !
The error still exists, then your entries in the ACP -> Portal Settings -> change in your "custom block settings for the center block" that:
search:
replace:
And then you still remove the "." from the portal_left.html who stands at the beginning:
.<!--version $Id: portal_left.html 591 2009-12-11 23:48:49Z marc1706 $ //-->
search:
/SagArtGiveaways.jpg" border="0" />Code: Select all
/SagArtGiveaways.jpg" border="0" style="margin-top: height: 200px; width: 350px;" />.<!--version $Id: portal_left.html 591 2009-12-11 23:48:49Z marc1706 $ //-->
