Portal Link display problem
Lucian_rider
phpBB.com User: Lucian_rider
Post by Lucian_rider »
Your Portal Version: 1.0.2
Boardlink: http://www.lucianriders.com/test/
Just installed Board3, problem was there from inception.
Checked all edits several times. Uploaded all files twice to their correct locations.
I just installed this fantastic mod on my test forum and everything seems to be working great except that in the board index page the portal link is not complete as shown here:
I have checked all edits and reloaded all files.
I look forward to any responses.
the.ronin
Re: Portal Link display problem
Post by the.ronin »
Try checking to make sure you have this in your language\en\common.php:
	'PORTAL_INDEX'			=> 'Portal',
Redo the changes in the includes/functions.php as described in the install.xml included in the portal package.
That will fix it.
There is nothing edited in the language\en\common.php for the portal.
the.ronin
Post by the.ronin »
Oops sorry about that. That was something I did myself.
Lucian_rider
Kevin wrote:Redo the changes in the includes/functions.php as described in the install.xml included in the portal package.
That will fix it.
Yes that fixed it! Strange, I did no edits, just moved them down a line and eliminated some blank lines and all's good...
