Boardlink: http://axio-matic.com
nothing
contact you
Im trying to add portal 1.0.4 to this custom style that was made for me but i cant find the subsilver edits for the overall_header.html heres the overall_header.html
<head>
{META}
// <![CDATA[
<!-- IF S_USER_PM_POPUP -->
if ({S_NEW_PM})
if (!name)
name = '_popup';
return false;
function jumpto()
var per_page = '{PER_PAGE}';
* Find a member
function find_username(url)
return false;
* Mark/unmark checklist
if (!parent)
if (!parent)
return;
rb[r].checked = state;
<!-- IF ._file -->
function play_qt_file(obj)
if (rectangle)
var width = 200;
var height = 0;
obj.width = width;
obj.height = height + 16;
obj.Play();
</script>
</head>
<a name="top"></a>
<div id="hbackground-right">
<div id="hbackground-left">
<div id="hbackground-centre">
<div id="wrapheader">
<div id="logodesc" style="text-align: center;"><object type="application/x-shockwave-flash" data="./styles/CS gamers/theme/images/header/header.swf" width="100%" height="140px"> <param name="wmode" value="transparent" /> <param name="movie" value="./styles/CS gamers/theme/images/header/header.swf" /> </object> </div>
<div id="menubar">
<td class="genmed" align="center">
<a href="{U_INDEX}"><img src="{T_IMAGESET_LANG_PATH}/forum.png" width="80" height="28" alt="*" /></a><!-- IF not S_IS_BOT --><a href="{U_LOGIN_LOGOUT}"><!-- IF S_USER_LOGGED_IN --><img src="{T_IMAGESET_LANG_PATH}/logout.png" width="80" height="28" alt="{L_LOGIN_LOGOUT}" /><!-- ELSE --><img src="{T_IMAGESET_LANG_PATH}/login.png" width="80" height="28" alt="{L_LOGIN_LOGOUT}" /><!-- ENDIF --></a><!-- ENDIF -->
<!-- IF U_RESTORE_PERMISSIONS --><a href="{U_RESTORE_PERMISSIONS}"><img src="{T_IMAGESET_LANG_PATH}/login.png" alt="{L_RESTORE_PERMISSIONS}" /></a>
<!-- IF S_BOARD_DISABLED and S_USER_LOGGED_IN --><span style="color: red;">{L_BOARD_DISABLED}</span>
<!-- IF S_USER_NEW_PRIVMSG or PRIVATE_MESSAGE_INFO_UNREAD -->
<a href="{U_PRIVATEMSGS}"><img src="{T_IMAGESET_LANG_PATH}/newpm.png" width="80" height="28"><span><!-- IF S_USER_NEW_PRIVMSG --><!-- ELSE --><!-- ENDIF --></span></a>
<a href="{U_PRIVATEMSGS}"><img src="{T_IMAGESET_LANG_PATH}/nopm.png" width="80" height="28"></a>
<!-- ELSEIF S_REGISTER_ENABLED --><a href="{U_REGISTER}"><img src="{T_IMAGESET_LANG_PATH}/register.png" alt="{L_REGISTER}" /></a>
<!-- ENDIF --><a href="{U_FAQ}"><img src="{T_IMAGESET_LANG_PATH}/faq.png" width="56" height="28" alt="{L_FAQ}" /></a><!-- IF S_DISPLAY_SEARCH --><a href="{U_SEARCH}"><img src="{T_IMAGESET_LANG_PATH}/search.png" width="80" height="28" alt="{L_SEARCH}" /></a><!-- ENDIF -->
<!-- IF S_DISPLAY_MEMBERLIST --><a href="{U_MEMBERLIST}"><img src="{T_IMAGESET_LANG_PATH}/members.png" width="80" height="28" alt="{L_MEMBERLIST}" /></a><!-- ENDIF -->
<!-- IF S_USER_LOGGED_IN --><a href="{U_PROFILE}"><img src="{T_IMAGESET_LANG_PATH}/ucp.png" width="58" height="28" alt="{L_PROFILE}" /></a>
<div id="datebar">
<div id="wrapcentre">
<p class="searchbar">
<span style="float: {S_CONTENT_FLOW_BEGIN};"><a href="{U_SEARCH_UNANSWERED}"><img src="{T_IMAGESET_LANG_PATH}/unanswered.png" width="100" height="20" alt="{L_SEARCH_UNANSWERED}" /></a><a href="{U_SEARCH_ACTIVE_TOPICS}"><img src="{T_IMAGESET_LANG_PATH}/active.png" width="100" height="20" alt="{L_SEARCH_ACTIVE_TOPICS}" /></a></span>
<span style="float: {S_CONTENT_FLOW_END};"><a href="{U_SEARCH_NEW}"><img src="{T_IMAGESET_LANG_PATH}/new.png" width="100" height="20" alt="{L_SEARCH_NEW}" /></a><a href="{U_SEARCH_SELF}"><img src="{T_IMAGESET_LANG_PATH}/your.png" width="100" height="20" alt="{L_SEARCH_SELF}" /></a></span>
</p>
<br style="clear: both;" />
