Boardlink: http://forums.clan-pgc.com
Nothing as far as i know. Everything was working fine last night. I woke up and the error was there.
Found a temporary solution by commenting out directoryindex in .htaccess. This bypasses the portal altogether and goes straight to the board index.
When attempting to view the portal on my website I received an Error 500: Script Execution Failure message. I installed the portal 4 or 5 days ago and everything was working great. This morning I woke up and a member told me they couldn't access the forum. The portal address is http://forums.clan-pgc.com/portal.php
The forum address is http://forums.clan-pgc.com. Before modifying .htaccess going to forums.clan-pgc.com redirected to http://forums.clan-pgc.com/portal.php.
This is a temporary fix and I'm hoping someone can help me figure out a solution to the problem so that my portal page works again.
Re: Error 500: Script Execution Failure
I had browsed that thread but hadn't thought that it would apply since I had just downloaded the portal Turns out I was wrong and the changes did need to be made, It didn't fix the problem though. As for my error log, it seems to be completely useless, it's empty. None of my logs make any reference the portal page. Restoring the forums from an earlier backup didn't help to fix the problem either.
Try asking your hoster, maybe they know more.
Tried that too, they're the ones that told me to modify the .htaccess file.
I'm going have to try uninstalling the portal and reinstalling, or just do without it.
i am getting a error just like this but, mine is when i try to go to the .mods part of my admin panel, this just started today, and what i did before it, was enabled custom block left and center and birthdays, THATS IT now i cant get back into it.
contacted my hosting company, they said possible htaccess problem, i looked at it shows normal.... and my problem is only with the .mods section and the mods pertaining to portal, i tried moving them to a new tab nope same problem sometimes maybe i can get in there but when i click on the mod i wanna edit times out.
any suggestion to modify ?
i went through the database and turned those mods back off, but still having same issue.
*** tried to edit last post would not edit for some reason **
i had a backup of a database from teh day before, i put the site on that, same issue, so it looks like it is a error in a file somewhere that is doing this.
Then again we don't have a timer in our files that causes errors. If it's in the ACP, try replacing the portal files in includes/acp/mods/ or re-upload the portal language files for the acp.
