How to change the title
AIpx
Post by AIpx »
Your Portal Version: 1.0.2
Boardlink: http://pokerhold-m.com
I look into differents files without success
nothing of more
Hello,
I would like to change the name of the portalboard page " portail" by the title of my website and i don't find where it is :( Someone can help me please ? Thanks very much ;)
Re: How to change the title
language/fr/mods/lang_portal.php
    // General
    'PORTAL'                => 'Portal',
AIpx
Post by AIpx »
Thanks kevin ! it's ok ;)
I have other questions if you can help me.
1) i use a redirection . How can i put the portal at http://www.pokerhold-m.com instead of http://www.pokerhold-m.com/PHPBB3 without using my index.htm page please ?
2) Where can i add meta description for the portalboard please ?
3) How can i change the color of block "menu" , "help" etc to have the same style as my forum please ?
4 ) How can i do the update 1.0.2 to 1.0.3 please ?
Regards,
Thanks ;)
Forum Rules wrote:Before creating a new support thread, please take a look in the board3 Portal FAQ and use the search!
  1. see above (board3 Portal FAQ)
  2. meta descriptions can be added in the overall_header.html - but this is for the complete forum. There is no way to add meta tags for the portal only
  3. see above (board3 Portal FAQ)
  4. update_board3portal_102.xml is included in the package, in the contrib directory
AIpx
Post by AIpx »
Kevin wrote:1) see above (board3 Portal FAQ)
Ok sorry and thank for the link , i will try to do that "Moving portal.php outside of your forums directory" :oops:
Kevin wrote:2 )meta descriptions can be added in the overall_header.html - but this is for the complete forum. There is no way to add meta tags for the portal only
Ok thanks, can i ask you an exemple please ? when i open my overall_header i can find :
<head>
<head>
{SEO_BASE_HREF}
<title>{PAGE_TITLE}<!-- IF S_IN_MCP -->{L_MCP} &bull; <!-- ELSEIF S_IN_UCP -->{L_UCP} &bull; <!-- ENDIF --></title>
<!-- // MOD : MSSTI RSS Feeds (V1.0.4) - Start-->
But i'm not a king in php :? Thanks
Kevin wrote:3 ) see above (board3 Portal FAQ)
Ok thank you vm
Kevin wrote:4) update_board3portal_102.xml is included in the package, in the contrib directory
I just try but i can't find :
"V'U_PORTAL'=> append_sid("{$phpbb_root_path}portal.$phpEx"), in includes / functions.php
and i can't find in the overall_header :
and i can't find
<li class="icon-home"><a href="{U_PORTAL}">{L_PORTAL}</a> &#187; <a href="{U_INDEX}" accesskey="h">{L_INDEX}</a></li>
but i have
<li class="icon-home"><a href="{U_INDEX}" accesskey="h">{L_INDEX}</a> <!-- BEGIN navlinks --><strong>&#8249;</strong> <a href="{navlinks.U_VIEW_FORUM}">{navlinks.FORUM_NAME}</a><!-- END navlinks --></li>
Sorry :oops:
AIpx wrote:Ok thanks, can i ask you an exemple please ?
Erm, taking a look into your source code brings up this:
<meta name="description" lang="fr" content="Portail Pokerhold-M : Passion Poker - Les bons plans poker : Passion Poker" />
<meta name="keywords"    content="Passion, Poker, plans, poker, bons, Les, Pokerhold, Portail" />
You already have meta tags given. ;)
AIpx wrote:I just try but i can't find : "V'U_PORTAL' => append_sid("{$phpbb_root_path}portal.$phpEx"),
Search for: U_PORTAL
Might be that you forgot to do this edit with V. 1.0.2 - i cant see the link in your forum. You might do the edits as stated in the install.xml
AIpx
Post by AIpx »
Thanks Kevin , i have try to do " Moving portal.php outside of your forums directory" and if avec the messages :
[phpBB Debug] PHP Notice: in file /homez.143/pokerhol/www/portal.php on line 22: main(./phpBB3/portal/includes/lang_adm_additional_blocks.php) [function.main]: failed to open stream: No such file or directory
[phpBB Debug] PHP Notice: in file /homez.143/pokerhol/www/portal.php on line 22: main() [function.include]: Failed opening './phpBB3/portal/includes/lang_adm_additional_blocks.php' for inclusion (include_path='.:/usr/local/lib/php')
[phpBB Debug] PHP Notice: in file /homez.143/pokerhol/www/portal.php on line 58: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3011)
Thanks
This file does not exist: http://www.pokerhold-m.com/phpBB3/porta ... blocks.php
It seems that you are using a portal.php from B3P package 1.0.3 without having properly updated to it (the rest of the installation is still v. 1.0.2).
The lang_adm_additional_blocks.php has been added in v. 1.0.3.
Use a portal.php of the 1.0.2 package or update to 1.0.3 before trying to move it outside the phpBB root directory.
Anotheridiot
phpBB.com User: Anotheridiot
Post by Anotheridiot »
Kevin wrote:language/fr/mods/lang_portal.php
    // General
I did this, but it has also changed a portal link I had in the main_menu.html
<li><a href="{U_PORTAL}">{L_PORTAL}</a></li>
and the link for portal in the overall header and overall footer breadcrumbs.
I have done the same thing in common.php for
'INDEX'						=> 'index',
But it has not ended up with the same result in the breadcrumbs.
Ive gotten around it in the main menu by changing
<li><a href="{U_PORTAL}">Home</a></li>
Now I'm poking around in overall header nad overall footer to see if I can figure out how to fix.
-Dan
_______________________________________
Lifes not fair... but the Root Password Helps !
Anotheridiot
the line in overall header is
				<li class="icon-home"><!-- IF U_PORTAL --><a href="{U_PORTAL}">{L_PORTAL}</a> &#187;
to be changed to
				<li class="icon-home"><!-- IF U_PORTAL --><a href="{U_PORTAL}">Home</a> &#187;
Overall footer edits are
change
			<li class="icon-home"><!-- IF U_PORTAL --><a href="{U_PORTAL}">{L_PORTAL}</a> &#187; <!-- ENDIF -->
to
			<li class="icon-home"><!-- IF U_PORTAL --><a href="{U_PORTAL}">Home</a> &#187; <!-- ENDIF -->
Templates need to be refreshed after these changes.
-Dan
Thanks for sharing, but this is not a good way to do it. What you have done now is to "hardcode" it and is more "quick & dirty" than anything else. You need to edit every file, that doesn't make no sense. Also this is not a solution for multilingual forums, e.g. French and English "Portail" and "Portal".
Simply change it in the language files, like i've told above:
language/ your language /mods/lang_portal.php
    // General
    'PORTAL'                => 'Whatever',
Change Whatever to the name you want to have for the portal link and description.
Don't forget to purge the cache afterwards. ;)
Anotheridiot
What my point was making that edit in lang_portal.php does change the page title, but it also changes the appearance of text for all occurances of {L_PORTAL} on the page.
So for example if it was to be changed to
        // General
        'PORTAL'                => 'WHATEVER',
The page title ends up as
WEBSITE * WHATEVER.
But the breadcrumbs in overall footer and overall header, all occurances of the {L_PORTAL} change to whatever as well.
So if you were viewing this forum it would read
* WHATEVER ‹ Board index ‹ Portal ‹ board3 Portal - English Support
Ive been studying some online marketing techniques lately and have discovered that google uses the page title like the cover of a book. The More descriptive the title, the more relevant hits your site will get.
Because Ive pretty much quoted from one of my study documents, I feel I have to mention that the document I have taken most of my start from is called Online Marketing by Damien Mulley
-Dan
Okay, but to just change the portal title it would have been easier to modify
// output page
page_header($user->lang['PORTAL']);
in portal.php and define an own variable, like "P_TITLE" or something and add it to the lang file.
Just one edit instead of several in several templates. ;)
Anyway, main thing is that you have what you wanted to have. ;)
Anotheridiot
Yeah that works much better.
I undid all my previous edits and went with the following. Much tidier and neater solution.
in portal.php
// output page
// output page
page_header($user->lang['PORTAL_TITLE']);
In /language/en/mods/lang_portal.php
	'PORTAL_INSTALL_TEXT'		=> 'An installation file has been detected. If you want to update your portal (or any other mod), please execute the installer. If you have already done so, please remove or rename the directory for security reasons.',
Add After
	'PORTAL_TITLE'			=> 'WHATEVER',
-Dan
Anotheridiot wrote:Much tidier and neater solution.
Yeah, i subscribe to that! :)
Have a nice weekend (public holiday today in Germany)!
