Your Portal Version: 1.0.4RC3
Boardlink: http://www.friendzsociety.com
Did not remember
Uninstall try Reinstall
i try to Uninstall the protal. Its says uninstall complete
But after i again brows the install direcory. there is no insall TAB.
Actually Acp Configration is no showing so i tried to uninstall and then Reinstall the portal
Uninstall / Reinstall
Khamosh-Saya
- phpBB.de User: Khamosh-Saya
- phpBB.com User: Khamosh-Saya
