Your Portal Version: 1.5
Boardlink: http://priscilafantin.nl/portal.php
Installed the portal just now.
The portal is too wide, any solutions or tips to get it fixed?
Portal too wide
rudolfpietersma
Re: Portal too wide
It seems this is due to a weird link in your announcements block. Please check if you maybe put a corrupt link or something like that in the block file.
What editor do you use to edit files?
What other MODs do you have installed?
By the way, you should probably edit your stylesheet.css in order to make your menu look right.
