I have some problems with the main menu. I dont know how to describe it så please take a look here: http://warezpeak.com/portal.php
Eivind
Menu Problem
Re: Menu Problem
that you forgot:
Open: styles/prosilver/theme/stylesheet.css
@import url("colours.css");Tip: Add these lines on a new blank line after the preceding line(s) to find.
@import url("portal.css");V.G. archivar
Re: Menu Problem
I have done that, nothing happens
eivind
eivind
Re: Menu Problem
Refresh your Styles:
Re: Menu Problem
Nothing Happens, still the same, maybe you can look at this file for me: overall_header.html
<head>
{META}
phpBB style name: prosilver
Based on style: prosilver (this is the default phpBB3 style)
Original author: Tom Beddard ( http://www.subBlue.com/ )
Modified by:
// <![CDATA[
var on_page = '{ON_PAGE}';
var per_page = '{PER_PAGE}';
<!-- IF S_USER_PM_POPUP -->
if ({S_NEW_PM})
var url = '{UA_POPUP_PM}';
* Find a member
function find_username(url)
return false;
window.onload = function()
eval(onload_functions[i]);
window.onunload = function()
eval(onunload_functions[i]);
</script>
</head>
<div id="wrap">
<div id="page-header">
<div class="headerbar">
<div id="site-description">
<h1>{SITENAME}</h1>
<p>{SITE_DESCRIPTION}</p>
<p class="skiplink"><a href="#start_here">{L_SKIP}</a></p>
<div id="search-box">
<fieldset>
</fieldset>
</form>
<li class="icon-home"><!-- IF U_PORTAL --><a href="{U_PORTAL}">{L_PORTAL}</a> » <!-- ENDIF --><a href="{U_INDEX}" accesskey="h">{L_INDEX}</a> <!-- BEGIN navlinks --> <strong>‹</strong> <a href="{navlinks.U_VIEW_FORUM}">{navlinks.FORUM_NAME}</a><!-- END navlinks --></li>
<li class="icon-ucp">
<a href="{U_PROFILE}" title="{L_PROFILE}" accesskey="u">{L_PROFILE}</a>
<!-- IF S_DISPLAY_PM --> (<a href="{U_PRIVATEMSGS}">{PRIVATE_MESSAGE_INFO}</a>)<!-- ENDIF --> •
<!-- IF U_RESTORE_PERMISSIONS --> •
</li>
<!-- IF not S_IS_BOT -->
<!-- IF not S_USER_LOGGED_IN and S_REGISTER_ENABLED --><li class="icon-register"><a href="{U_REGISTER}">{L_REGISTER}</a></li><!-- ENDIF -->
<div id="page-body">
Reason: please post code in a codebox
Re: Menu Problem
I cant see any Problem on your Menu... Maybe you have to refresh your browsercache...
Re: Menu Problem
I tryed it in IE and now it's working fine, Browser cache was the solution..... Thank's
