Tables cause errors
iRas
Translator
Tables cause errors
Post by iRas »
Board3 Portal: 2.0.0b1
phpBB: 3.0.9
The introduction of tables causes errors when displaying templates of Artodia:
http://www.forum.dreammail.pl/portal.php?style=59
After adjusting the files from version 1.0.6 with no tables, the effect is correct:
http://www.forum.dreammail.pl/portal.php?style=58
Other suggestions?
iRas
Re: Tables cause errors
I've seen that they have made ??incorrect changes to the styles.
In the original styles, there is not the problem.
iRas
Translator
Post by iRas »
Hmm... my English is bad too...
Thank you for the hint. It was even worse.
I used the wrong portal templates. Subsilver2 instead of prosilver.
It is now OK.
http://www.forum.dreammail.pl/portal.php?style=67
iRas
Return to “Styles Support”
