Addon Version: 1.0.1
Addon Author: Talonos
Addon Description:
This is a guild recruitment display module. Specs are displayed on the portal via images and transanercy for images is set in the ACP. also you can set a numeric value (0-5) AND/OR a Priority level (none-low-medium-high), these 2 values will display in a nice mouseover tooltip that is customisable from a theme dropdown menu. you can set the block to only display classes that you are recruiting for OR display all classes. Class images can be enabled/disabled. Class name colors can be enabled/disabled. Clicking on a spec image will direct you to the forum/link of your choosing for said clicker to make an application to the guild be it from an application form or a forum which is custonisable from the ACP aswell
Addon Requirements: Board3 Portal 2.0.0b1 and newer.
Download Link is here:
http://pretereo-stormrage.co.uk/viewtopic.php?f=5&t=16
Instructions:
2. Add new module into left or right column of the portal (ACP > MODS > Portal > Portal Modules).
Demo: http://pretereo-stormrage.co.uk/portal.php Blocks on the Left are the current working Modules. others displayed there currently are not available yet unless stated
REVISION INFOMATION
1.0.1
Improved Tooltip Stability
Initial Release
