A Block I am working on
hooplah
Post by hooplah »
A little guidance please.
i have created this in the portal/blocks folder called reviews.php
// how many rows to show per page
$rowsPerPage = 2;
// by default we show first page
$pageNum = 1;
// if $_GET['page'] defined, use it as page number
if(isset($_GET['page']))
	$pageNum = $_GET['page'];
// counting the offset
$offset = ($pageNum - 1) * $rowsPerPage;
$query  = "SELECT * FROM phpbb_reviews LIMIT $offset, $rowsPerPage";
$result = mysql_query($query) or die('Error, query failed');
// print the results in a table
while($list = mysql_fetch_array($result))
	$template->assign_block_vars('reviews_row', array(
		'R_TITLE'				=> $list['title'],
		'R_REVIEW'			=> $list['review'],
		'R_INFO'				=> $list['info'],
		'R_IMAGE'				=> $list['image'],
		'R_LINK'				=> $list['link'],
		'R_ED2K'				=> $list['ED2K']
this to output the results in styles/portal/blocks
<!--version $Id: reviews.html 321 2008-08-17 10:17:11Z kevin74 $ //-->
<table width='100%' border='1'>
    <td colspan='3'>
    <div align='center'>{reviews_row.R_TITLE}</div>
     <td width='25%'>&nbsp;</td>
     <td width='3%'>&nbsp;</td>
     <td width='72%'>Review</td>
    <td>{reviews_row.R_TITTLE}</td>
   <td>&nbsp;</td>
    <td>{reviews_row.R_REVIEW}</td>
     <td>&nbsp;</td>
     <td>&nbsp;</td>
     <td>&nbsp;</td>
    <td>
   <td>&nbsp;</td>
    <td>{reviews_row.R_INFO}</td>
     <td>&nbsp;</td>
     <td>&nbsp;</td>
     <td>&nbsp;</td>
    <td><a href="{reviews_row.R_LINK}">Board Link</a></td>
   <td>&nbsp;</td>
   <td><a href="{link.URL}" title="{link.TEXT}">{link.TEXT}</a></td>
    <td>{R_ED2K}</td>
added the following to portal.php
		include($phpbb_root_path . 'portal/block/reviews.'.$phpEx);
included the file in the portal_body.html
The table shows on the portal but not the variables. What have i missed please? ;)
Re: A Block I am working on
Set a
<!-- BEGIN reviews_row -->
and the end statement in your template. ;)
hooplah
Post by hooplah »
Thanks for the quick reply buddy. Works a treat. ;)
hooplah
Post by hooplah »
what is the best and safest way to run the sql for this block, i know there are built in db connections and certain ways to query the database.
I have two queries;
1. the alternative to the way i tested this I believe I don't require.
$con = mysql_connect("localhost","root","");
if (!$con)
  die('Could not connect: ' . mysql_error());
  mysql_select_db("sharessoul", $con);
2. how would i format this qurey?
these two variables are used elsewhere to provide paging elsewhere, many thanks for your help. :D
hooplah
Post by hooplah »
tried the following to connect
$sql  = "SELECT * FROM phpbb_reviews LIMIT $offset, $rowsPerPage";
got this error
[phpBB Debug] PHP Notice: in file /portal/block/reviews.php on line 14: mysql_connect() [function.mysql-connect]: Can't connect to local MySQL server through socket '/tmp/mysql.sock' (2)
Could not connect: Can't connect to local MySQL server through socket '/tmp/mysql.sock' (2)
I would try this:
$sql = 'SELECT *
    FROM ' . REVIEWS_TABLE . '
$result = $db->sql_query_limit($sql, $offset);
and add to the includes/constants.php
define('REVIEWS_TABLE',                $table_prefix . 'reviews');
Superman
Post by Superman »
This sounds like something I could use (see my topic in block requests). Is this something that will be released?
hooplah
Post by hooplah »
Sorted it thanks Kevin.
I hadn't thought about releasing this block but if there is interest then I could release it once completed.
Will give you more info about it when I get a working version finished. ;)
Superman
Post by Superman »
That would be great. here is what I am looking for (as posted in another topic)
I'm relaunching my site and it will be geared to A/V and HD related topics. Some of that is going to be Blu-Ray movie reviews. What I would like is a simple block of recent topics, but only pointing to one particular forum (in this case, the forum for the Blu-Ray reviews). I have that forum set to display in the News blocks, but often they don't stay up very long due to the other news being posted throughout the day. A dedicated block would be helpful.
You can view my site here.
It sounds like the same thing you are trying to do. If you can get it to work and would be willing to share, that would be great. Thanx. :)
digitales
Post by digitales »
This might suit my needs too. Can you tell me how it looks when installed? I need to have a Recent Topic block that displays topics from the whole forum, but also an additional Recent Topic block that pulls topics from one forum. Is that the general idea of this block?
