block questions
MarkDome
block questions
Post by MarkDome »
i've posted this earlier on phpbb.nl and phpbb.com but they could't help me.
The gave the advise to go through this supportboard. It's about the blocks in board3 offcourse
In the ACP I can't find a thing to edit/delete the blocks
At the installing i change this 2 files:
http://forum.potterdome.com/install.xml
http://forum.potterdome.com/xml/subsilver2.xml
  • Modificatie & Versie: board3 version 1.0.2
    Directe link to modificatie: http://www.board3.de
    Adres forum: http://forum.potterdome.com
    phpBB version:3.0.2
    Have you reently istalled modificatie or styl?
    board3 and template blackgreen_box
    What is the problem?
    How can i edit blocks
    Like: welkom to my community in the block welcome
    And i dont mean this:
    'WELCOME'            => 'Welcome',
    Wat did i all ready?
    i've searhed through:
    portal.php
    portal/block/welkome.php
    languages/nl/mod/lang_portal.php
    styles/blackbox_green/template/portal/portal_body.html
    How can i delete blocks from the portal
    Like: block clock/random_member
    portal/block/random_member deleted
    portal.php
    if ($portal_config['portal_random_member'])
    	include($phpbb_root_path . 'portal/block/random_member.'.$phpEx);
    changed in
    /*if ($portal_config['portal_random_member'])
    But it still stay on my portal
    How can i add new blocks
    I want static pages, those must come in the middle of the page.
    $link = explode($url)
    if(link == page1){ TExT }
    if(link == page2){ TExT }
    Its realy much haha so I hope someone will answer me :)
    thanks so far
Re: block questions
MarkDome wrote:How can i edit blocks
Erm, you can edit the text of the welcome message in the ACP!?
Maybe i don't get what you mean?
MarkDome wrote:How can i delete blocks from the portal
Disable the block in the ACP.
Or just remove the template calls in the portal_body.html
e.g the random block - remove:
        <!-- IF S_DISPLAY_RANDOM_MEMBER -->
            <!-- INCLUDE portal/block/random_member.html -->
        <!-- ENDIF -->
Purge the board cache afterwards.
MarkDome wrote: How can i add new blocks
viewtopic.php?f=21&t=310
MarkDome
Re: block questions
Post by MarkDome »
So you can read here that I installed it good I think, but can't find mod in the acp
but must add only this line
$user->add_lang('mods/lang_portal_acp_logs');
and thats not really much
so did I something wrong by the install?
and kevin thanks for the answers :)
Huor
Re: block questions
Post by Huor »
Hi MarkDome,
once you have uploaded the portal files (in the style folder) to your server they will be cached (if default settings are used). Then you have to edit the files though your ACP -> Styles -> Templates...
I had the same problem at the start - i tried to change something in the files, even purged the cache, but nothing changed until i edit them though the ACP.
If you don't see the MODs tab in your ACP you have not activated it?! Its in the ACP -> System -> Administration Control Panel (enable the module it should be there already).
If you don't want any thing displayed in the portal delete the entries from the portal_body.html - like you did - but only through the ACP.
Or finally after you changed the file on your server you can refresh the style even through the ACP - but keep in mind that eventually other changes made through the ACP will get lost if you haven't saved them either in the files yet.
Re: block questions
For each box there is an option in the ACP (.MODs --> Portal) to disable it. Why don't you use it? Just a few clicks and it's done.
It sounds to me like you don't have executed the installer for the portal. Otherwise you should see the ACP options for the portal.
Huor
Re: block questions
Post by Huor »
Kevin wrote:For each box there is an option in the ACP (.MODs --> Portal) to disable it. Why don't you use it? Just a few clicks and it's done.
yeah he could do so,
but he mentioned he doesnt see the mod tab in the ACP ;) Thatswhy i mentioned to edit the portal_body.html through the ACP ;)
Nevertheless both methods will work^^
