[EN] Weatherforecast with User ZIP code (weather.com)
Myaj
Re: [EN] Weatherforecast with User ZIP code (weather.com)
Actually, Marc, that worked for viewing the page in IE, I always forget to double check that.
Firefox still is off center, but its now centered for IE users, thank you.
zappa84
it didn't work for me..
it messed up all my fonts (they are huge now) and the images isn't centered.. any clue??
here the screenshot... i'm using portal 1.03 if it helps..
zappa84
zappa84
guys no help at all with this??
Topic author - Site Admin
Link to your forum?
zappa84
thanks for your reply. i restored the original file because it's my live forum, so i couldn't wait... but i would like to have this mod working on my forum..
here it is the link: http://www.newage-os.org
like i said in the first post :t messed up all my fonts (they are huge now) and the images isn't centered..
So if you could help me to understand the problem , it would be great..
zappa84
it's me again.. did anybody figure out the problem?
I don't see any weather box on your site, i just see a screwed up portal. So it's hard to say where to begin and i guess that you have done something wrong with the edits. Try doing the edits from scratch while searching this complete topic. You might also try a different service than accuweather.
There have been many tips and solutions within this topic.
stitch
- phpBB.com User: stitch625
Hello all,
Just dropped in and seen this mod. OMG!!! I have been wanting amod like this ever since phpbb3 came about. There has been a weather mod in development for over 2 years now and I can't wait any longer.
I see that this mod is for a portal. I do not use a portal on my board but would like to integrate this into my index page. I have tried using the code that is provided here but when I use
But all I get is a blank page unless I comment it out. How hard would this be to do? Any help would be greatly appreciated. Like I said I have been searching for mod like this for over 2 years now.
Thanks
// Weather START
include($phpbb_root_path . 'includes/weather.' . $phpEx);
// Wether END But all I get is a blank page unless I comment it out. How hard would this be to do? Any help would be greatly appreciated. Like I said I have been searching for mod like this for over 2 years now.
Thanks
mikey12561
Just so you know the first edit that you have for prosilver which is this edit
Open: styles/prosilver/template/portal/portal_body.html
This is supposed to be portal_center.html
The edit isn't in the body. Just so you know.
I also want to point out this edit\
Its wrong and should be this
Mind you all of this was on PHPBB 3.0.6
// Weather START
include($phpbb_root_path . 'portal/block/weather.'.$phpEx);
// Wether END Its wrong and should be this
// Weather START
include($phpbb_root_path . 'weather.'.$phpEx);
// Wether END -
weave
I am getting this error on my portal page
[phpBB Debug] PHP Notice: in file /includes/functions.php on line 3840: Cannot modify header information - headers already sent by (output started at /portal/block/weather.php:1)
That line in functions.php says:
header('Pragma: no-cache');
DragonMaster
- phpBB.com User: DragonMaster1
weather.com has changed it's code and has caused a few problems for other applications also. Although my portal is running ok, it might mess up the ones outside of the usa
weave
I think my issue is that the weather.php code was modified by the guy who already had zip code and his modified code was put in as the standard code....
Until I get some ideas, I removed all the code
Xmes
- phpBB.com User: Xmes
Hello!
I don't find in the styles/prosilver/template/portal/portal_body.html and in the styles/subsilver2/template/portal/portal_body.html this code:
Where is this?
Where do I insert this html code:
Thank you!
<!-- IF S_DISPLAY_WELCOME -->
<!-- IF S_DISPLAY_WELCOME_GUEST and S_USER_LOGGED_IN -->
<!-- INCLUDE portal/block/welcome.html -->
<!-- ENDIF --> Where do I insert this html code:
<!-- Weather Start -->
<!-- INCLUDE portal/block/weather.html -->
<!-- Weather End --> -
styles/*yourstyle*/template/portal/portal_center.html
