Center block width!
deaftone
Center block width!
Post by deaftone »
Boardlink: http://www.deaf-monkey.com/forum/portal.php
Hey guys, i've gone through the entire english support section to find out how to adjust the center block width, and i have followed all the different suggestions including changing the settings in the News section to not display replies and views and etc. but even after that i still needed some extra width for my center blocks to make it look the way I want it which is when i found a thread that said to edit portal_body.html and change
<table cellpadding="0" cellspacing="0" border="0" width="100%">
to
<table cellpadding="0" cellspacing="0" border="0" width="1024">
which is the width that i want. But this is what happens when i do that.
Before changes:
http://www.deaf-monkey.com/beforechanges.gif
After changes:
http://www.deaf-monkey.com/afterchanges.gif
Just wondering why the entire table is not centered properly and how can i change it! Thanks alot guys.[/i]
deaftone
Re: Center block width!
Post by deaftone »
Oh, one more thing, it goes out of alignment everytime i put a width value of more than 800px! Thanks again guys.
Ice
Post by Ice »
The problem is that the theme you use is "fixed width" so even though you make the central column wider, the blank space to the left of the page doesn't shrink to accommodate it. I'm not as savvy with design as some other people, hopefully they can explain further.
deaftone
Post by deaftone »
I actually just found a solution. All i had to do was edit common.css change the width values for #wrap. Problem resolved! Thanks guys.
