SQL errors
japagun
phpBB.com User: japagun
SQL errors
Post by japagun »
Your Portal Version: 1.0.2
Boardlink: [url]http://localhost%20sorry[/url]
nothing, just finished the languague translation, and tried to update the DB to the version 3.0.4 i didn't have success, if i tried to enter in index.php, everything is gone fine....... but when i click in portal, or type portal.php in my browser, i have errors with mysql....
searched here, but nothing help me yet
SQL ERROR [ mysql4 ]
Error writing file '/tmp/MYP5T7uS' (Errcode: 28) [3]
SQL
SELECT topic_title, forum_id, topic_id FROM phpbb_topics WHERE topic_status <> 2 AND topic_approved = 1 AND topic_type = 0 AND topic_moved_id = 0 ORDER BY topic_time DESC LIMIT 10
BACKTRACE
FILE: includes/db/mysql.php
LINE: 174
CALL: dbal->sql_error()
LINE: 221
CALL: dbal_mysql->sql_query()
FILE: includes/db/dbal.php
LINE: 170
CALL: dbal_mysql->_sql_query_limit()
FILE: portal/block/recent.php
LINE: 122
CALL: dbal->sql_query_limit()
FILE: portal.php
LINE: 80
CALL: include('portal/block/recent.php
[/i]
japagun
Re: SQL errors
Post by japagun »
up
Re: SQL errors
Are you working with a local server, like XAMPP?
This points to missing writing access for temp files / wrong directory permissions. So i guess you need to edit your server configuration.
japagun
Re: SQL errors
Post by japagun »
Kevin thanks for your reply, but did you know where i can set this configures???? When i activate the wordgraph, the same errors appears......
Re: SQL errors
Just tick the magic switch.
Maybe i can say more as far as i find my glass bowl. ;)
Seriously: with the information you gave at this time, i can say nothing. You haven't even answered my last question.
japagun
Re: SQL errors
Post by japagun »
i didn`t saw your reply above sorry...
Yes i`m using xampp
Re: SQL errors
So this is the only hint i have for you:
This is definitely a XAMPP / Windows configuring issue.
Please refer to the belonging support forum.
japagun
Re: SQL errors
Post by japagun »
Kevin wrote:So this is the only hint i have for you:
I`ll see if i have any answers from their....thanks for now....
