Boardlink: http://ipro.vn
PHP Version: 3.0.4
1) I want to move all blocks from Right column to Left column in the Portal. Because I want to save space to extend the width of Center Block.
2) I also want to add meta tags keyword/ Google analytic scripts into the header page of Portal
Help me please
1) I already change the Portal_body.html block from Right to Left, But nothing happen
2) I already change the Overall_header.html to add the custome code but nothing happen
Help me please
Thanks you so much for your kindly help
Move all Right Blocks to Left Blocks and Add custome code
Re: Move all Right Blocks to Left Blocks and Add custome code
Did already purged your caches?
knowledge/kb_show.php?id=28
