Dass das ganze jetzt zerschossen ist, ist übrigens ganz normal.
Error column cannot be null
Re: Error column cannot be null
Wie sieht denn deine styleswitcher.js aus? Wenn die den Fehler verursacht, dann sollte man sich die Datei halt mal ansehen.
Razer
Danke fuer deine Hilfe! Hier die Datei:Marc wrote:Wie sieht denn deine styleswitcher.js aus? Wenn die den Fehler verursacht, dann sollte man sich die Datei halt mal ansehen.
function fontsizeup()
var active = getActiveStyleSheet();
switch (active)
case 'A--':
setActiveStyleSheet('A-');
break;
case 'A-':
setActiveStyleSheet('A');
break;
case 'A':
setActiveStyleSheet('A+');
break;
case 'A+':
setActiveStyleSheet('A++');
break;
case 'A++':
break;
default:
break;
function fontsizedown()
switch (active)
case 'A++' :
break;
case 'A+' :
break;
case 'A' :
break;
case 'A-' :
setActiveStyleSheet('A--');
break;
case 'A--' :
break;
default :
break;
function setActiveStyleSheet(title)
var i, a, main;
for (i = 0; (a = document.getElementsByTagName('link')[i]); i++)
if (a.getAttribute('rel').indexOf('style') != -1 && a.getAttribute('title'))
a.disabled = true;
if (a.getAttribute('title') == title)
a.disabled = false;
function getActiveStyleSheet()
var i, a;
if (a.getAttribute('rel').indexOf('style') != -1 && a.getAttribute('title') && !a.disabled)
return a.getAttribute('title');
return null;
function getPreferredStyleSheet()
return ('A-');
function createCookie(name, value, days)
if (days)
var date = new Date();
date.setTime(date.getTime() + (days*24*60*60*1000));
var expires = '; expires=' + date.toGMTString();
expires = '';
document.cookie = name + '=' + value + expires + style_cookie_settings;
function readCookie(name)
var nameEQ = name + '=';
var ca = document.cookie.split(';');
for (var i = 0; i < ca.length; i++)
var c = ca[i];
while (c.charAt(0) == ' ')
c = c.substring(1, c.length);
if (c.indexOf(nameEQ) == 0)
return c.substring(nameEQ.length, c.length);
return null;
function load_cookie()
var cookie = readCookie('style_cookie');
var title = cookie ? cookie : getPreferredStyleSheet();
setActiveStyleSheet(title);
function unload_cookie()
var title = getActiveStyleSheet();
createCookie('style_cookie', title, 365);
onload_functions.push('load_cookie()');
onunload_functions.push('unload_cookie()');
var cookie = readCookie("style");
Du hast bei deinem Style ein prosilver- und ein subsilver2-basierendes Style zusammengemischt. Bei subsilver2 (AeroBlue) gibt es z.b. keine styleswitcher.js. Ich kann mir deine Probleme nur damit erklären, dass diese Mixtur deine Probleme verursacht. Könntest du die styleswitcher.js wieder reinstellen und dein Forum wieder aktivieren? Ich würde gerne etwas versuchen.
Razer
Klar!Marc wrote:Du hast bei deinem Style ein prosilver- und ein subsilver2-basierendes Style zusammengemischt. Bei subsilver2 (AeroBlue) gibt es z.b. keine styleswitcher.js. Ich kann mir deine Probleme nur damit erklären, dass diese Mixtur deine Probleme verursacht. Könntest du die styleswitcher.js wieder reinstellen und dein Forum wieder aktivieren? Ich würde gerne etwas versuchen.
Ist aktiviert!
Razer
Marc, eine Frage, brauchst du einen FTP - Zugang?
Komisch ist, dass bisher alles EINWANDFREI funktioniert hat. Dann kam der grosse Ansturm und der Fehler.
Versuch mal folgendes:
Gehe in deinen Admin-Bereich
Klicke oben auf Styles und danach in der linken Spalte auf Templates.
Bei deinem Style klickst du dann in der Optionen Spalte auf Details. Dort stellst du dann bei "Templates ablegen in:" Dateisystem ein.
Razer
Danke, jedoch bekomme ich den fehler, wenn ich versuche, es umzustellen:Marc wrote:Versuch mal folgendes:
Warning
The template file was unwritable so the template set is now stored in the database containing the modified file.
EDIT: Nein, sie hat 777.
Razer
Mal eine Frage, kennst du dich mit MySQL aus?
Vll. sagt dir das was, mir nicht:
http://bugs.mysql.com/bug.php?id=2508
Razer
Habe noch etwas recherchiert, aber kenne mich mit MySQL nicht so aus:
http://www.interaktonline.com/Support/K ... +null.html
Razer
Noch komisch, mit Safari wird immer nur dieser kurze Fehler angezeigt:
SQL ERROR [ mysqli ]
Column 'template_filename' cannot be null [1048]-
- phpBB.de User: Christian_N
- phpBB.com User: Christian_N
Hab dir ne PN geschickt...
Und bitte beachte unsere Foren-Regel zwecks Topic-Bumping du hast jetzt 4 Beiträge in Abstand von 5-10Minute geschrieben was nicht erwünscht ist hier.
Quelle: viewtopic.php?f=40&t=1631
- Stil
- Topic-Bumping Das Hochschubsen eines Themas ist erst nach Ablauf von 24 Stunden zulässig.
Ändere mal die Berechtigungen für den "style"-Ordner und seine Unterordner auf 755.
Razer
Leider immernoch der selbe Fehler, wenn ich versuche, es zu aendern. Brauchst du FTP ZUgang oder MySWL Zugang?Marc wrote:Ändere mal die Berechtigungen für den "style"-Ordner und seine Unterordner auf 755.
Am besten beides.
pablowestenhaver89
I've gone this also. It is really not possible.
Being stressed out and overweight may not be YOUR fault! It's true, a mysterious condition might be to blame. An estimated 70-80% are suffering from this condition, and don't even know it!
http://www.howtocurecandida.com/survey/
