Boardlink: http://frc.exofire.net/forums/
I just installed PHPBB and Board3
I've tried playing with the style's settings in the way prosilver's were described but it didn't work. I also tried the 1.0.2 version.
I am quite new to PhpBB and board3 as well. My clan is considering moving to a new website and new forums and they've asked me to look into phpbb. Some of the other members and I have fallen in love with the Dark Fantasy style and want to use it with Board3 to make a complete site. However, while Dark Fantasy looks amazing in the forums, on the portal it looks less than average and not even worth using. Is there any way that someone can update the Dark Fantasy style for 1.0.3?
Thank you,
Kez
						Dark Fantasy Update
Re: Dark Fantasy Update
Your Style is based on subsilver2. You install it by using pprosilver files. This is why it looks so ugly
So how would i go about fixing it? I'm sorry, like I said I'm quite new so I don't know much when it comes to all of this.
Or is not possible to fix and it's better to just choose a new style?
After you installed this Style, you installed the Portal for this Style by copying the files from our download in this Style folder.
Now you have to do the same, but instead of using the prosilver files, you just have to take the subsilver2 files. You have to overwrite all existiong files, if you where asked.
